Rear cylinder will not fire - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 21 (permalink) Old 12-04-2015, 01:44 AM Thread Starter
I am getting no spark on my rear cylinder I have checked everything I can think of hopefully someone can shed some light ... Bike is a 2001 vn750 it was having troubles with not firing when the bike warmed up before so I went to do a pickup coil mod and a wire broke off the pickup coil so I bought a new one ohmed out great installed it and now the rear cylinder won't fire at all both pickups ohms are correct switched coils still front fires rear doesn't changed wires from front to back still no spark on the rear now the pickup I put on was off a 88 vn 750 and I just clipped wires and soldered and used shrink wrap instead of putting in both new pickups can someone please tell me what else to check or something before I set it on fire lol thanks guys
Camshaft is offline
post #2 of 21 (permalink) Old 12-04-2015, 01:59 AM
Crowley
crowley1027's Avatar
Check your spark plugs first. Figure out the condition of the rear plugs in particular. check the ignition coil that is bolted to the front of the battery box (I don't know any troubleshooting off the top of my head for that - I think you check voltage at each terminal while grounded to frame).
Pull the plug and ground it reliably to the something. Try different grounds, I've found some spots to be no good for ground. Make sure to ground out both plugs.
If indeed there is no spark from either, it's certainly electrical. It's just a matter of going to a starting point, and moving forward.
crowley1027 is offline
post #3 of 21 (permalink) Old 12-04-2015, 04:04 AM Thread Starter
I have checked the coil also have checked continuity of the wires and plugs work fine in the front cylinder they are fine the wires going to the coil 12v on one and the other is fire signal anyways to bypass those or check for shorts?
Camshaft is offline
post #4 of 21 (permalink) Old 12-04-2015, 07:12 AM
Try swapping coils
post #5 of 21 (permalink) Old 12-04-2015, 08:20 AM
Since you swapped igniton coils, did the bypass, etc, I am wondering if your pickup coil wire has been damaged for the rear cyl. Should be in the bundle of wires coming out of the stator cover, not the 3 for the stator but the other set of wires. There are also ohm tests for the pickup coils. Worth doing that to see if you had a issue with the wire for the rear pickup.
post #6 of 21 (permalink) Old 12-04-2015, 08:53 AM
Try swapping coils
I need to learn how to read
post #7 of 21 (permalink) Old 12-04-2015, 11:10 AM Thread Starter
I already tested the pickup coils they ohm out good
Camshaft is offline
post #8 of 21 (permalink) Old 12-04-2015, 11:23 AM
Crowley
Have you tried pulling a rear plug, and grounding it out with the wire attached while cranking?
post #9 of 21 (permalink) Old 12-04-2015, 02:42 PM
When you switched coils, did you switch the plug wires too? Perhaps it's a bad spark plug lead....
post #10 of 21 (permalink) Old 12-04-2015, 03:05 PM Thread Starter
Yes and yes I also check continuity on all 4 wires to be sure they are all good...I'm guessing it's bad wiring somewhere could the cdi box make it only fire the one cylinder
Camshaft is offline
