Charging issue - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
post #1 of 17 (permalink) Old 11-21-2015, 07:27 PM Thread Starter
Let's Ride!!
DaveT319's Avatar
Charging issue
Hey guys, I haven't been on here for a while, partly because I wasn't riding much, and partly because I wasn't having any problems. Well, now I am doing both.
Trying to figure out of it's the stator or R/R that has gone bad. Fully charged battery was indicating over 13 volts. Start the bike, and it was showing under 12. Revving up to 3-4K made no difference. So started running through the tests. The stator grounding test gave me a reading of OL on all three leads. Resistance between each lead was giving me 13.5-14.5 on the 200 setting on the multimeter. Next tested the R/R with the bike off (can't remember if supposed to do this with bike on or off) and got OL on every single combination of lead to lead checks.
So my conclusion is that the R/R is what's bad. But can you confirm the readings I got for the stator are OK? I haven't checked the output voltage yet as I need my wife to be home to turn up the throttle.
DaveT319 is offline
post #2 of 17 (permalink) Old 11-21-2015, 09:35 PM
Test AC voltage between all 3 legs of the stator. You should see 30-70v or so depending on RPM. You've determined it's not grounding out, and resistances are good, but not that it's output is good. You are already aware, but this will tell you 100%
The R/R you should be doing diode tests. Follow this. It will at least confirm it's the R/R.
https://www.electrosport.com/media/p...ng-diagram.pdf
HarryS likes this.
post #3 of 17 (permalink) Old 11-24-2015, 07:35 PM Thread Starter
Let's Ride!!
DaveT319's Avatar
Alright, I'll check that next, and do the diode test if it passes.
Thanks.
DaveT319 is offline
post #4 of 17 (permalink) Old 12-05-2015, 04:07 PM Thread Starter
Let's Ride!!
DaveT319's Avatar
Turns out it IS the stator. Putting out 3, 10, and 14 volts. Crap! Guess I'll be doing the stator mod then, cuz I do NOT want to take the time and effort to drop the engine again. Going to buy gcextreme's stator plate and do the mod next week. Now just need to buy a stator, and still need to test the R/R to confirm it's dead. What a pain.
DaveT319 is offline
post #5 of 17 (permalink) Old 12-05-2015, 10:16 PM
You can go with my alternator mod if you don't care about keeping it looking stock check it out in the projects and build section its a sticky
post #6 of 17 (permalink) Old 12-06-2015, 10:46 AM
I would replace the R/R too.
post #7 of 17 (permalink) Old 12-08-2015, 07:38 PM Thread Starter
Let's Ride!!
DaveT319's Avatar
I was thinking that too. Since the other tests I have done already seemed to indicate it was toast, might as well go ahead and put a new one in.
DaveT319 is offline
post #8 of 17 (permalink) Old 12-08-2015, 07:43 PM Thread Starter
Let's Ride!!
DaveT319's Avatar
Very clever project, but I think I prefer the internal one. Thanks for the suggestion though.
DaveT319 is offline
post #9 of 17 (permalink) Old 12-08-2015, 08:42 PM
a good upgrade since your going to replace the stock R/R is to upgrade to a mosfet type. they are more effecient and run cooler than the stock.
this is a good all in one kit for the upgrade
Shindengen MOSFET FH020AA Regulator Rectifier Kit Replaces FH012AA | eBay
michiganteddybear is offline
post #10 of 17 (permalink) Old 12-08-2015, 10:21 PM
Wink
x2
Have the same kit on mine, it's been working great, well worth it and not hard to wire up.
