Plastic connector for Rectifier Regulator - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 07-24-2008, 12:57 PM Thread Starter
The plastic connector that plugs into the R/R on my bike has been melted away by battery acid and I assume it would be a good idea to replace so nothing gets shorted out.
Does anyone know where I can get one of these molex style connectors?
natxbrotha is offline
post #2 of 16 (permalink) Old 07-24-2008, 01:07 PM
dirtrack650's Avatar
R U sure it's not due to heat?
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #3 of 16 (permalink) Old 07-24-2008, 01:37 PM
Chucklehead
dragon159's Avatar
In the past I have just clipped off the plug (noting which wire goes where) and replace the ends with spade connectors. Doesn't look quite as nice but I'm more for the function.
"Squirrel Bike" aka Jersey
Rat bike with a good PR agent
shaved and coastered
2 into 1 exhaust
rear 170 and front 110
custom dash with voltmeter
Spitfire windscreen
Plutonium plugs
More to come
dragon159 is offline
post #4 of 16 (permalink) Old 07-24-2008, 01:49 PM Thread Starter
Honestly I'm not sure if it's from heat or the acid... but the connectors are corroding and there was battery acid all over them, so I just assumed that the acid had something to do with it.
The bike had the goats belly on it, but I just put on Vance and Hines pipes so I should not have to relocate the R/R right?
post #5 of 16 (permalink) Old 07-24-2008, 01:59 PM
Chucklehead
dragon159's Avatar
Acid usually doesn't bother plastic That's why the battery cases are plastic. But heat does. Whether from the goat belly or short in the wire.
2 into 1 exhaust
Spitfire windscreen
Plutonium plugs
More to come
post #6 of 16 (permalink) Old 07-24-2008, 03:48 PM
hosedragger105's Avatar
The only place I have been able to find the connectors is at Electrosport.com. Look in the Street bike section, then under Accessories. THey have a connections and wiring section. I recommend moving your R/R from the stock location to a plate on the left side of the frame behind the left cover plate next to the rear wheel. Good luck.
I'm the pedifamilious! BONAFIDE!
hosedragger105 is offline
post #7 of 16 (permalink) Old 07-24-2008, 08:17 PM Thread Starter
You recommend this even though the only heat effecting it is from itself?
post #8 of 16 (permalink) Old 07-24-2008, 08:45 PM
Yeah... Funny. If the R&R is remaining & the exhaust moved. The R&R should be fine. But moving the R&R to the side makes it even more effective. The wind on long rides would help keep it cool.
post #9 of 16 (permalink) Old 07-24-2008, 08:47 PM
Sky Rider's Avatar
It will prevent acid from getting on it and corroding the connectors which could have contributed to the heat. With corroded connections, resistance goes up and so does the heat generated by them. This alone could account for the burnt connector. Besides, it makes the R/R that much easier to get to and only takes about 20 minutes to do once you have all the materials.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #10 of 16 (permalink) Old 07-24-2008, 11:12 PM
Crobins365's Avatar
After my r/r went, I became obsessed (for awhile) with seeing where they're placed on other bikes. Most often they seem to be located on the lower front of the bike where they can get a full blast of air. Given that the charging system is a weak point on the 750s, relocating - even on a degoated bike - is good preventive maintenance (and one of the few cheap fixes!!).
C
Crobins365 is offline
