Starting Problem - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 07-24-2008, 12:50 PM Thread Starter
Starting Problem
My VN750 still hasnít left me stranded, but the 'hard to start' is getting worse. Opening up the choke is not working. The only way I can get it started is kick-starting it. Tuesday, last night and this morning I had to kick-start it also (I drove it to work today). It turns over, but just wonít start using the starter button. The starter is good and the battery is good. Does anyone know what the problem can be? Is there any harm done by kick-starting?
ramoan is offline
post #2 of 11 (permalink) Old 07-24-2008, 12:56 PM
clean your carbs
85 VN750 basketcase ( yes its a true 750, and no smog controls, its good to be Canadian)
It will have
a rebuilt 96 top end, rebuilt 85 bottom end
degoated, Eared
stripped, lowered, raked, bobbed,
reed valve boxes shaved
ported and polished
balanced
right side dump exhaust
heads and cylinders shaved for compression
looking for smoothbore sidedraft carbs
possibly fat bob tanks
modified vn800 or sportster drag pipes or I'll just make some
Chopperfix
Duck's Garage
Duck is offline
post #3 of 11 (permalink) Old 07-24-2008, 01:52 PM
On His Lady Vulcan
wkrizan's Avatar
Originally Posted by ramoan View Post
My VN750 still hasn’t left me stranded, but the 'hard to start' is getting worse. Opening up the choke is not working. The only way I can get it started is kick-starting it. Tuesday, last night and this morning I had to kick-start it also (I drove it to work today). It turns over, but just won’t start using the starter button. The starter is good and the battery is good. Does anyone know what the problem can be? Is there any harm done by kick-starting?
How in the hell do you Kick start the bike that doesn't come with a kick start? You stated that your battery is good, did you take it in and have it load tested or are you checking it with just a meter? Battery's can hold a good surface charge but put a load on it and they can be as good as a huffer in the wind. My recommendation it to take the battery down to any auto parts place have them load test it and if it fails then its a must to purchase a AGM M/F battery.
Peace
Pictures of the "Ladies"
wkrizan is offline
post #4 of 11 (permalink) Old 07-24-2008, 01:58 PM
Chucklehead
dragon159's Avatar
Unless the start switch isn't making correct contact ....
Just my $.02
"Squirrel Bike" aka Jersey
Rat bike with a good PR agent
shaved and coastered
2 into 1 exhaust
rear 170 and front 110
custom dash with voltmeter
Spitfire windscreen
Plutonium plugs
More to come
dragon159 is offline
post #5 of 11 (permalink) Old 07-24-2008, 02:36 PM
ExNewbie..Still Learnin'!
rsawyer's Avatar
Do check the battery as suggested. BUT if the battery is good, and turns over strongly, then it sounds like you're may not be getting spark or a fuel issue. Try pulling your plugs one at a time and resting them against the outside of the engine (away from the opening), plug wire attached and use the starter button and see if you can see the spark. If not or it's weak, then you might try new plugs and see what happens. If it's strong then it's a fuel mixture issue.
Wkrizan - I think he means "jump-starting" like I've had to do tons of times with my old Mustangs....neutral, ignition on, push, run, jump, 1st gear, release clutch, gas, pray it starts.....never tried it with my bike but saved many a long walk home when the 'Stang was feeling ornery.
Hope it helps and good luck!
'89 Vulcan 750
VROC# 30232
HID Headlamp Conversion
V&H Cruzers (great sound)
Kaw V-Force Windshield
Kaw Rear Luggage Rack
Kaw Engine Guard
VN750.COM Grill Cover
W&M Black Magic Saddlebags
Diehard M/F Battery
R/R Replaced/Relocated
Stator Replaced
Voltmeter Installed
Splines Lubed
Metzler 880 Marathons
Front - 110/90-19
Rear - 170/80-15
Carbs Balanced
Carb Mix Adjusted
Fuel Tank Derusted/Lined/Sealed
NGK Iridium Plugs
rsawyer is offline
post #6 of 11 (permalink) Old 07-24-2008, 02:57 PM
On His Lady Vulcan
wkrizan's Avatar
After some thought I figured he meant compression starting but one never knows with all the mods that goes into bikes, maybe he installed a kick start some how or his PO did at some point. I think its a great idea to have one due to bikes weak electrical systems, If my battery dies at home I am screwed sense I live on the down side of a very steep driveway.
Peace
wkrizan is offline
post #7 of 11 (permalink) Old 07-24-2008, 03:14 PM Thread Starter
THANKS everyone. I meant jump-starting (but not with jumper cables, pushing the bike). I'll get the battery tested. May be spark plugs. The battery is M/F.
ramoan is offline
post #8 of 11 (permalink) Old 07-25-2008, 11:00 AM
rsawyer's Avatar
Peace
Sorry to hear that. Guess it would be tough to get the clutch back in and hit the brakes prior to going through the back wall of the garage. Maybe with a little practice????
Anyway, glad to know the jump start works in case it happens to me....
'89 Vulcan 750
VROC# 30232
Kaw Engine Guard
Diehard M/F Battery
Stator Replaced
Voltmeter Installed
Splines Lubed
Front - 110/90-19
Rear - 170/80-15
Carbs Balanced
Carb Mix Adjusted
NGK Iridium Plugs
rsawyer is offline
post #9 of 11 (permalink) Old 07-25-2008, 02:14 PM
If the batt is good the problem continues, the starter may be the problem. A dragging starter will pull a large amount of amps leaving the ignition system weak.
post #10 of 11 (permalink) Old 07-26-2008, 11:58 AM
Search Goddess
Dianna's Avatar
Following the starting check, if the battery is good, contacts at the starter solenoid are clean then you might want to pull the starter motor and clean it up. There is a fine silt that can creep into the starter motor and cause it to "drag"
Usually though, a good healthy battery and a set of iridium plugs cures most hard to start problems.
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
