Discharge at idle - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 10-20-2015, 12:45 AM Thread Starter
Discharge at idle
Is it pretty normal to see a slight battery discharge at idle? I'm original stator, regulator etc.
-Robert
RobertGary1 is offline
post #2 of 9 (permalink) Old 10-20-2015, 07:46 AM
What do you mean my "discharge"? If you mean total charging volts drop a bit, yes, that's normal.
You should be getting 12.8 volts or higher at idle, and they should go up to around 14.8 when the engine is spinning faster.
post #3 of 9 (permalink) Old 10-20-2015, 12:28 PM Thread Starter
Like battery voltage is around 12.5 with the bike off and around 12 with the bike idling.
-Robert
post #4 of 9 (permalink) Old 10-20-2015, 03:24 PM
How many volts at 5000?how old is the battery?
post #5 of 9 (permalink) Old 10-20-2015, 07:57 PM Thread Starter
Well that's an interesting story. I was having problems with occasionally weak/low battery so I installed a voltmeter. It showed voltage 13.5-14 but sometimes 11 at cruise. So as a test I tossed in a $20 regulator just to see what happens. Now I'm generally not less than 13.5 but I've seen 16. Its odd that its not consistent.
Battery is a few years old AGM but tested good.
-Robert
post #6 of 9 (permalink) Old 10-21-2015, 12:31 PM
You see 16v?! That fries batteries.
post #7 of 9 (permalink) Old 10-21-2015, 01:21 PM
Well before you freak out, try using another voltmeter to check your voltage ...at the battery. I've seen meters be off by 1-1/2 volts or so.
Stator output is never consistent as engine speed changes output. Generally volts are lowest at slow (idle) speeds and highest at high speeds...which if you think about it should make sense...
post #8 of 9 (permalink) Old 10-26-2015, 01:58 PM Thread Starter
The high voltage may have been a grounding issue. I built a ground strap for the regulator and took a short ride and it seemed to stay below 14.5. I'll test it out some more. I did the relocation (at least partially) but the frame is not grounded.
-Robert
post #9 of 9 (permalink) Old 10-26-2015, 02:08 PM
My battery terminal loosened up once and the voltmeter stayed on 15v.
