Asking someone with a multimeter to verify - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 07-17-2008, 11:50 AM Thread Starter
Chucklehead
dragon159's Avatar
While The Other Woman is down I've taken the opportunity to repair a few things other than the motor. One of these was the fuel guage that told me I was always empty. Took out the sending unit and found a broken connection at the output rivet and soldered it back together. Now for peace of mind I'm wondering if someone would check resistance values on thier sending unit to see if I'm in the ballpark at least. Currently I get 17 ohms at what would be full tank and 116 ohms at empty. If nothing else I'll just have to wait until the electricals get hooked back up to test but I thought I'd ask anyway.
dragon159 is offline
post #2 of 11 (permalink) Old 07-17-2008, 12:18 PM
hosedragger105's Avatar
I have the service manual at home, but am currently at work. I will check the values for you when I get back this afternoon and drop them on here asap.
hosedragger105 is offline
post #3 of 11 (permalink) Old 07-17-2008, 12:35 PM Thread Starter
Chucklehead
dragon159's Avatar
No hurry ..... Won't have the new motor until next week anyway.
post #4 of 11 (permalink) Old 07-17-2008, 12:43 PM
This help?......
post #5 of 11 (permalink) Old 07-17-2008, 01:25 PM
Now what
Ironman's Avatar
While you're messing around with the fuel gauge, maybe you'd like to try something for us. I've read that putting a 150 ohm resistor in line will one of the leads will help make the gauge more accurate. I have an adjustable resistor that I was going to use but of course, haven't gotten around to it. Personally, I'd like the gauge to be accurate at 1/2 a tank. (I don't even dare to dream that it could be accurate over the whole range) I figure accurate at 1/2 would be way more useful than say, accurate at empty So if someone (hint, hint) could figure out what resistance would accomplish this, it would be a great thing for Vulcankind.
'04 750A- and loving it!
VROC 13864
Using a Purlator One PL14610
Ironman is offline
post #6 of 11 (permalink) Old 07-17-2008, 01:40 PM Thread Starter
Chucklehead
dragon159's Avatar
Originally Posted by hyperbuzzin View Post
This help?......
It would if only this stupid work comp would let me see those pics lol. They won't even let me look at ebay or craigslist. and the comp is down at home.
I will even check accuracy when I do get it all back together, right now I'm tickled that it may actually work for a change .... keep forgetting how many miles to reserve, and that kept changing too.
post #7 of 11 (permalink) Old 07-17-2008, 02:55 PM
Sky Rider's Avatar
I don't think the 150 ohm resistor would work since the empty range maxes at 120 ohms with a min of 70. Your tank would be perpetually empty. Now a 50 ohm may work, but then the tank would never be full since it's between 3-20 ohms. 20 ohm or less resistor maybe???
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #8 of 11 (permalink) Old 07-17-2008, 03:15 PM
Well then, here's what it says....
Fuel Level Sensor Resistance:
  • Full Position- 3 to 12 ohm
  • Empty Position- 70 to 120 ohm
post #9 of 11 (permalink) Old 07-17-2008, 03:51 PM Thread Starter
Chucklehead
dragon159's Avatar
Thank you so very much, at least now I know I'm in the ballpark and the hotdog vendor just slipped on a mustard pack ... beer is on me
post #10 of 11 (permalink) Old 07-17-2008, 04:17 PM
The info provided by our esteemed, hyperbuzzin, is confirmed to be correct. Not that it really needed to be. Also, according to the service manual to check the gauge operation, it says to short the leads. CAUTION!!!Do not short the leads longer than necessary. When the hand swings to the "F" position, stop short circuiting. The gauge should read "F" when shorted. If this happens then you unit is good.
This information came from the 14th Edition Service Manual.
Good luck.
