The Two Wire Mod - Page 19 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 17Likes
post #181 of 185 (permalink) Old 06-05-2019, 11:01 AM
Originally Posted by Ron Ryman View Post
I did this yellow /red and . red /black cut from J.B.and joined togather. If I do not want to do the blue wire mod ? Do I want to connect these 2 wires back to the cut yellow /black ?? I left enough of both attached to the plug to join them???
Sent from my SM-J700T1 using Tapatalk
Ron Ryman is offline
post #182 of 185 (permalink) Old 06-05-2019, 01:19 PM Thread Starter
Originally Posted by Thorn View Post
Change "done correctly" to "splicing the black into the yellow/red, but leave the yellow/red connected to the JB" and I'll agree. Every schematic I've seen indicates that the removal of the yellow/red wire from the JB removes the ground path for the primary coil of the headlight relay, requiring the blue-wire mod to be done to get your headlight back.
You may be right, and I'm not able to study the diagrams at the moment, or review this thread.
I already had the Blue Wire mod done when I did the Two-Wire.
My position has been to take as much away from the JB as possible, I would sell the bike before keeping the headlight relay.
Keeping the JB relays in operation is just asking for trouble later.
Ron Ryman likes this.
post #183 of 185 (permalink) Old 06-05-2019, 02:59 PM
I did this yellow /black. red /black cut from J.B.and joined togather. If I do not want to do the blue wire mod ? Do I want to connect these 2 wires back to the cut yellow /black ??
Yes, connect the spliced wires back to the yellow/black connection on the JB.
I heartily agree with Spockster that the blue-wire mod is the better alternative. ESPECIALLY when chasing gremlins, since these relays are known failure points that can cause grounding issues.
Vulcan slang for newcomers
Service Manual Download
Thorn is online now
post #184 of 185 (permalink) Old 06-05-2019, 04:16 PM
Doing the blue wire mod. when moving the blue wire out of the plastic connection is it best to push it out with a small screw driver or can it be pulled out successfully? Is cutting it and sealing the ends an option? thank you.
post #185 of 185 (permalink) Old 06-05-2019, 05:38 PM Thread Starter
There's a tiny lock tab on the copper spade. I use a sewing needle to push the tab, then the spade slips right out. Paper clip was too large.
