The Two Wire Mod - Page 18 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 13Likes
post #171 of 175 (permalink) Old 06-22-2018, 12:23 PM
vulkan's Avatar
Don't get me wrong...I'm all for "the easy hot start"!!
vulkan is offline
post #172 of 175 (permalink) Old 06-22-2018, 12:49 PM Thread Starter
No. The two cut wires on the JB plug don't get spliced together. Just insulate the ends. You are splicing the two wires in the harness together.
Originally Posted by vulkan View Post
1) At the Junction Box, find the 10-pin connector (smaller of the two)
2) Locate the yellow/red stripe and black/red stripe wires (Kawi also used all black instead of black/red)
3) Remove the two wires from the 10-pin plug
4) Splice the two wires together securely and insulate properly.........That's it!! OK that's not confusing,remove these two wires from 10 plug JB (Took me a few minutes...Junction Box!!) Splice these two "loose" wires TOGETHER...DONE!!So you do NOT cut wires then splice the two cut wires on the "plug" side together,coming out of the JB(??)....or do you splice the "longer" loose cut wires heading "out back" together??I know these questions are Moronic,guess it would make sense to splice the two coming out the JB.BUT...LOL if you remove the wires from the JB,then splice...its like connecting two "loose" wires,same as cutting them and NOT going through the JB.
post #173 of 175 (permalink) Old 06-22-2018, 06:09 PM
vulkan's Avatar
OK thanks....hope my headlight functions!!
vulkan is offline
post #174 of 175 (permalink) Old 03-13-2019, 12:55 PM
I have the same problem after I did the the wire snip on r&r
did you find out how to fix it?
glenn is offline
post #175 of 175 (permalink) Old 03-16-2019, 11:27 AM Thread Starter
Arrow
Be sure you're working on the 10-pin connector.
Thorn suggested the Blue Wire Mod in the other thread... Did that work for you?
