Something with the Charging System - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 08-30-2015, 12:37 PM Thread Starter
TechMech's Avatar
I'm in the process of reading through all the information on testing the charging system to see if it's the stator or the R/R (which was replaced way back when). I'm reading low voltage at the battery with the engine running (under 12v). When I rev the engine, the voltage goes up a little (just over 12v). Does this give me any indication of what is wrong or is it always a matter of going through all the checks?
Thanks...
TechMech is offline
post #2 of 3 (permalink) Old 08-30-2015, 02:05 PM
No it really doesn't point to the problem, just shows that it's not charging right.
Need to go through all the checks for the stator and R/R.
post #3 of 3 (permalink) Old 09-19-2015, 03:49 PM Thread Starter
TechMech's Avatar
I just finished replacing the R/R. With the engine running, I'm reading 14.x volts at the battery connections. I got a Caltric R/R off Amazon for $21. I wish I had done that a long time ago...
TechMech is offline
