Blowing headlight fuse. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 07-10-2008, 09:34 AM Thread Starter
Hey guys and gals, I so appreciate all your helpfull info since recently buying my bike and now have an issue i hope you can help with. I removed my headlight to get to a tun signal lead. now everything works but the headlight fuse keeps blowing as soon as you start the bike. I just for the sake of knowing installed a 30 amp (didn't have any more 10's) and of course the bandage worked fine, at least for the five minuites it sat there running(it was 2:00 am under the house outside at this point. Any ideas. please respond if so as I am supposed to go on a ride I've been waiting for and I would like Murphy (Murphy's Law) to kick back for this one. I would appreciate any help any of you might have as I have not seen many threads matching this. Thanks.
GETNAWAY is offline
post #2 of 9 (permalink) Old 07-10-2008, 10:32 AM
ChrisC's Avatar
My guess is that you are shorting to ground somewhere in the headlight bucket. I would remove the headlight again and check the wires. Maybe there is a sharp edge in there that you made contact with when putting the headlight back in the first time, or crossed an exposed lead.
Chris
Wayne, NJ
1989 VN750-A5
VROC #27781
-MF Battery
-De-Goated/Re-goated
-Coastered
-Splines Lubed
-Stebel Nautilus Horn
-AutoMeter 2" VOM
-Silverstar Headlight
-Plexifairing III
ChrisC is offline
post #3 of 9 (permalink) Old 07-10-2008, 10:43 AM
Search Goddess
Dianna's Avatar
I agree with Chris. When things go wrong best way to figure out is.. what has changed to cause it. Also one good reason to do things one at a time so you have less steps to re-trace.
The bucket isn't real roomy in there and chances are you have a pinched wire that is causing the short. Should be easy enough to check.
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #4 of 9 (permalink) Old 07-10-2008, 11:17 AM Thread Starter
RE: Blowing Headlight Fuse
Thanks Guys, guess it's back to basics. I'll find it, as not riding is not a consideration.
GETNAWAY is offline
post #5 of 9 (permalink) Old 07-10-2008, 11:28 AM
liljd's Avatar
Ditto on the others posts....Just make sure to take that 30 amp out!!!! Put in a 10 amp or you may short out the whole thing and that will be bad!!
James
1985 vn700 (T'Plana)
Gremlin bell
HD-O shield
saddlebagged
custom made supports
tool bag
extended backrest
Protac backrest
Highway pegs
custom mirrors
custom grips
V&H cruisers
lever covers
DieHard AGM
Kuryakin battery gauge
and LED taillights
marbled
____________________
VROC #27169
Tn VROC #134
www.youtube.com/thetrueliljd
liljd is offline
post #6 of 9 (permalink) Old 07-12-2008, 02:35 AM Thread Starter
RE: Blowing headlight fuse
Thanks for your responses, seems that a PO left some exposed connections in headlight housing and now they're not! No Mo blown fuses. Next is the 6" rise Drag Bars. Thanks again to the community.
GETNAWAY is offline
post #7 of 9 (permalink) Old 07-12-2008, 02:36 AM
ChrisC's Avatar
Glad you got it resolved!
Chris
Wayne, NJ
1989 VN750-A5
VROC #27781
-MF Battery
-Coastered
-Splines Lubed
-AutoMeter 2" VOM
-Plexifairing III
ChrisC is offline
post #8 of 9 (permalink) Old 07-12-2008, 04:56 AM
Way to go!!!
post #9 of 9 (permalink) Old 07-12-2008, 09:55 AM
Search Goddess
Dianna's Avatar
I love easy fixes!
Dianna
Conway, AR
Patriot Guard Rider
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
