HELP - no lights, horn, gas gauge, tach - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 07-09-2008, 09:29 PM Thread Starter
got my bike serviced and when i got home last night, nothing on the dash worked except the turn signals and i had no lights.
i lost power to:
tach & temp sensor (fan worked though)
gas gauge
horn
front light
rear brake light
it seems something lost power - and it powers everything. i took the light off last night and checked all the connections and also took the dash apart to make sure everything was ok as well. i also checked the fuses in the junction box and they are fine.
i know what you will say - take it back, but the dealer (private shop) had it for 3 weeks for a carb cleaning and they didn't do it. i was told the pipes (mac) will make the bike sputter because they need more fuel (rejet). they charged me $120 to install some fuel filters, back out the air screws and solve a wiring issue that i was unaware of.
i would like to fix this issue - or at least mess something up trying- before i bring it back to them
njrealtor55 is offline
post #2 of 9 (permalink) Old 07-09-2008, 10:38 PM
Crobins365's Avatar
I'm trying to read the wiring diagram in the Haynes manual (it's in color, so that helps) and here's what I can see: the water temp sensor, tach, and tach light all go into what appears to be a five-pin connector(R/BL, BR, BK/Y, BK, and Y wires); the Black/Yellow lead serves as the ground connector for your headlamp, but also your front left turn signal - so that doesn't make sense. However, the BR wire from that lead serves as the power wire for your horns, so that helps. The BK/Y of the fuel gauge also grounds to the same lead (the sensor is a two-prong connection under the saddle - the gauge itself operates on its own circuit). I'm pretty sure that connector can be found under your left front engine cover (two screws - big phillips head) - see if they forgot to hook that up, or didn't fully hook it up. I'll go out and see what color that connector is - back in a flash.
Hmm...short term memory here on wire colors, but I think the connector is probably the red one. There's also a five-pin brown connector located in the same vicinity - might as well check both while you're in there.
C
Crobins365 is offline
post #3 of 9 (permalink) Old 07-10-2008, 01:57 AM
ChrisC's Avatar
What was the wiring issue that they "fixed"? I would do a quick check in that vicinity; especially if it coincides with the location(s) that Cindy mentioned.
Chris
Wayne, NJ
1989 VN750-A5
VROC #27781
-MF Battery
-De-Goated/Re-goated
-Coastered
-Splines Lubed
-Stebel Nautilus Horn
-AutoMeter 2" VOM
-Silverstar Headlight
-Plexifairing III
ChrisC is offline
post #4 of 9 (permalink) Old 07-10-2008, 09:06 AM
liljd's Avatar
Try cleaning the junction box with a plastic safe contact cleaner. It may help may not but it's a shot.
James
1985 vn700 (T'Plana)
Gremlin bell
HD-O shield
saddlebagged
custom made supports
tool bag
extended backrest
Protac backrest
Highway pegs
custom mirrors
custom grips
V&H cruisers
lever covers
DieHard AGM
Kuryakin battery gauge
and LED taillights
marbled
____________________
VROC #27169
Tn VROC #134
www.youtube.com/thetrueliljd
liljd is offline
post #5 of 9 (permalink) Old 07-11-2008, 02:02 PM Thread Starter
the tech told me that every time he turned right the bike died. he took the key ignition assembly apart and sanded the contacts. he didn;t really charge me for the repair of that issue.
i called him and he said that the key routes the power to those items - and trying to fix the bad connection that caused the stalling prob ruined the power connection to the accessories.
i have a new key/ignition on order.
i wish there was a way to jump it out. i have to wait 7-10 business days and really want to ride.... especially considering the shop had the bike for almost 3 weeks
post #6 of 9 (permalink) Old 07-11-2008, 02:25 PM
Undercover Sportbiker
AJCruzin's Avatar
There are 2 big connections on the left side of the neck (as you sit on the bike). Try unplugging them and then reconnecting them. Maybe it's just not seated correctly?
AJCruzin is offline
post #7 of 9 (permalink) Old 07-11-2008, 03:56 PM
Crobins365's Avatar
Again, looking at the wiring diagram, the Br/Wh wire off the ignition switch looks to be a critical connector. It should have a bullet connector that goes into a female connector off a Br wire in the wiring harness. Unless he totally destroyed it, all you need is to solder a piece back on there and hook it up. Look under the left side engine cover and see if that female lead is open - if that's it, and you can solder (or somebody at the dealership can), you should be up and running in about 15 minutes.
C
post #8 of 9 (permalink) Old 07-11-2008, 05:14 PM
Agrees with the above...
post #9 of 9 (permalink) Old 07-11-2008, 08:53 PM Thread Starter
i looked at the wiring diagram in the manual and traced the rear light to the red wire that goes into the key switch. i figured that it wasn't seeing power, so i grabbed an extra battery and put power there with a small piece of wire (at the red wire under the key switch).
everything worked as it should. i am guessing the connection in the switch itself is messed up - as the dealer told me it prob was (he took the key switch apart to clean it).
so, i ran some wire from the red wire at the key switch to a temp rocker switch and then to the battery. basically i am turning the accessories on by switch after the key switch is turned on.
since i ordered another key switch, i figured this fix is temp. (splicing into the key switch wires) at least it gets me back on the road after 3 weeks of driving my jeep.
