Stalling when turning bars all the way to the right. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 08-06-2015, 09:26 PM Thread Starter
FastHamFreddy
FastHamFreddy's Avatar
When I am turning my bike right (hard right) while moving or at a stand still the bike will stall. It turns right back on, and the electric stays on as well,l. But the engine will die.
Would this be a bare wore causing this? If so is there a place I should start looking that someone else has had the same problem?
As always thanks guys!
FastHamFreddy is offline
post #2 of 4 (permalink) Old 08-06-2015, 09:34 PM
Follow the kill button wiring and inspect the harness.
'99 VN750, all stock
performed driveshaft maintenance
checked the ACCT using the Grambo Trick
Sycned carbs with flow meter
Yuasa YTX14AHL-BS AGM Battery
NGK DPR7EIX-9 Irridium Spark Plugs
vulcan1999 is offline
post #3 of 4 (permalink) Old 08-07-2015, 01:53 AM
2000 VN 750 Senior Member
Check at the neck cover area and especially where you see the locking tab that holds the handlebars turned to the left when the key is in the locked position.
Tom
Vulcan 2000
4507 miles
Vulcan2000 is offline
post #4 of 4 (permalink) Old 08-07-2015, 02:22 AM
o n the left side of the bike, under the neck cover are three connectors, a brown one, a white one and a red one... check to make sure there is enough slack on the forward side of the connectors that they don't pull tight when you turn right...
