Anyone installed a Digital Voltmeter? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 18 (permalink) Old 07-03-2008, 11:43 PM Thread Starter
Love My Baby
rubyrick's Avatar
I recently had to replace my stock battery. Got a MF AGM from Sears and learned a lot about my baby in the process. Now I think it would be a good idea to permanently install a digital voltmeter so I can constantly monitor the battery. Any suggestions on which meter, or how and where to install it? I've been using my battery tender quick connect as the contacts for my hand-held meter, but I can't use that while I'm riding and it's a bit of a pain to test the volts while applying the throttle to get 3-5000 RPMs.
I would like something that looks like a stock component once installed. Also I'd like to be able to hit a button and get a volt reading when the bike is OFF, too. Is there such a beast out there?
rubyrick
'05 VN750
rubyrick is offline
post #2 of 18 (permalink) Old 07-04-2008, 12:32 AM
I used this one:
http://tinyurl.com/6ajen
Simple, uses so little power I had it wired directly. Only bad part I guess it is not lighted.
If want a lit one, (I ride little at night) many FJR folks use this one:
http://tinyurl.com/83v9g
It is made to mount in a panel, but you could simply install it in a metal or plastic plate and mount it where ever you wish.
I mounted the first one on my "dash":
http://tinyurl.com/2csf7y
Guess you could make something simular....
post #3 of 18 (permalink) Old 07-04-2008, 01:01 AM Thread Starter
Love My Baby
rubyrick's Avatar
Thanks for the URLs. I'd like to see a few more meters before I decide. I'll also be thinking about where to install. I'm not quite as adept at building dashboards as U R. Nice work KM...
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #4 of 18 (permalink) Old 07-04-2008, 03:25 AM
dirtrack650's Avatar
I was thinking digital and found some nice ones on eBay for less than $10. Another source for our bikes would be a boating or tractor outlet: both those products need to be weather resistant. I ended up using analog meter to match the style of the tach and speedo.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #5 of 18 (permalink) Old 07-04-2008, 04:10 AM
liljd's Avatar
I used this
http://www.kuryakyn.com/products.asp?bn=metric&ci=2695
Not digital but effective. it reads how the battery is doing. I hooked mine up to the battery posts with a switch,
James
1985 vn700 (T'Plana)
Gremlin bell
HD-O shield
saddlebagged
custom made supports
tool bag
extended backrest
Protac backrest
Highway pegs
custom mirrors
custom grips
V&H cruisers
lever covers
DieHard AGM
Kuryakin battery gauge
and LED taillights
marbled
____________________
VROC #27169
Tn VROC #134
www.youtube.com/thetrueliljd
liljd is offline
post #6 of 18 (permalink) Old 07-04-2008, 11:20 AM
Undercover Sportbiker
AJCruzin's Avatar
It's not digital, but here's another option. Kanuck and I and (I think) a few others have done it this way.
https://www.vn750.com/forum/showthrea...ight=voltmeter
AJCruzin is offline
post #7 of 18 (permalink) Old 07-04-2008, 01:49 PM
Vulcan Traitor ;)
Send a message via Yahoo to Keemez
I bought one of these and will be installing it in the next week or so, along with my LED aux lights that I mentioned in another post several weeks ago. I like the look of this one.
http://www.advancedjdmparts.com/zoom...roductid=20124
Keemez is offline
post #8 of 18 (permalink) Old 07-07-2008, 09:29 PM Thread Starter
Love My Baby
rubyrick's Avatar
Hey Keemez, I like the look of your new voltmeter, too. Found it online for $15.99 and I'm considering this one. After your install, could you send a pic of how it looks? Also let me know how easy the install went, mounting included? Thanks...
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
X
rubyrick is offline
post #9 of 18 (permalink) Old 07-16-2008, 12:30 AM
Vulcan Traitor ;)
Finally
Ok- finally got all my brackets made up and everything installed/functional. There was quite a delay because I was waiting on one of the machinists at work to do some metal cutting for me and he was on vacation for a week... etc etc etc.
The voltmeter bracket is custom-fabbed (and not entirely to my liking, but it'll work) from 1/16" stainless steel. Here's a front and rear shot of that:
Here it is installed in place, but not powered:
Powered but not quite dark outside:
And powered while dark (a bit blurry- hard to avoid):
The worst part was trying to putz with the stainless- that was some bullet tough material and in spite of it being hard, the dang thing vibrates a fair bit between around 2000 and 3500 rpm. I might have to cram some sort of a rubber wedge down under the meter to hold it from moving as much. It's pretty annoying. Also this gauge is very difficult to read in bright light/sunlight because the lens face is "smoked". At night it's fine but if you're going to buy this model for yourself be prepared to have a hard time reading it while the sun is out. But- the whole point is that at least I can monitor the electrical system now, and it kinda looks cool too.
Keemez is offline
post #10 of 18 (permalink) Old 07-16-2008, 12:58 AM
ChrisC's Avatar
I originally had the Kury VOM installed:
https://www.vn750.com/photopost/showp...00&ppuser=4374
The problem was, it blinded me at night! Also, it seemed that the light from of the LED's reflected off of the other housings, throwing off the day/night sensor, causing it to glow at daytime brightness. Also, I wanted a bit more info about what the charging system was up to so I went with this one:
It is an AutoMeter installed in an Equus gauge pod. I fabbed the bracket using a strong tie and damped the vibrations using a rubber grommet. The gauge can be lit with either green or red light. I used the green and it matches the other gauges really well. I also reversed the housing ring colors as compared to the other gauges cause I liked the way it looked. Wired directly to the battery using a relay. Works great!
Chris
Wayne, NJ
1989 VN750-A5
VROC #27781
-MF Battery
-De-Goated/Re-goated
-Coastered
-Splines Lubed
-Stebel Nautilus Horn
-AutoMeter 2" VOM
-Silverstar Headlight
-Plexifairing III
ChrisC is offline
