"Testing Electrical Parts for Idiots" - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 07-03-2008, 11:06 PM Thread Starter
Addicted to Projects
bullwinkle's Avatar
Has anybody got one I can buy/rent/download?
I purchased a multi Pro'sKit 903-150 multi tester but can't understand how to get readings. Heck I can't seem to even get readings across the coil and I know that I have spark.
Can anyone give me an Idiots guide to help understand the settings. I have the Clymers book, so I know where I should be and what the readings are supposed to be, but I don't know how to set the tester to get the readings.
Any help/tips/advise?
Charlie
VN700 project bike 98% completed!!
68 Bushwhacker this winters project (in the works)
86 Honda GL1200i (winter project #2)
82 kz440 daily rider for now!
A few clowns short of a circus now aren't we?
bullwinkle is offline
post #2 of 3 (permalink) Old 07-03-2008, 11:24 PM
Love My Baby
rubyrick's Avatar
I recently bought a cheap radioshack digital multimeter. When testing the battery you need to set it to 0-20 DCV (direct current volts) because you're testing a 12 volt DC battery and 0-20 it the most appropriate range.
I suggest you send a PM to slimvulcanrider because he helped me out with an electrical problem and he is the man... who can...
There are many others on this forum much brighter than I, who have been most gracious in helping out fellow riders. Someone will reply.
rubyrick
'05 VN750
rubyrick is offline
post #3 of 3 (permalink) Old 07-04-2008, 05:31 AM
liljd's Avatar
mostly they are easy enough to set but to understand leaves me in the dark at times. I hope this helps as it's just some of the info needed like I said I'm still lost with these too but getting better.
DCA or ADC is Amps in DC current. while testing amperage.
DCV or VDC is Volts in DC current. as in car battery.
ACV or VAC is Volts in AC Current. such as in wallplug
OHMs is the symble that looks like a set of head phones. (Do not have juice in wires while in this mode) used to test continuety and resistance.
To find the number needed for test such as in the battery, You know it's a 12 volt battery so use the next highest number which is 20 set in DCV mode and place black probe to the negative terminal and the red to the positive and you'll get the Volts in DC and Viola!
also if need for the charging system go here and also download the PDF on the page
http://www.electrosport.com/technica...ding-guide.php
James
1985 vn700 (T'Plana)
Gremlin bell
HD-O shield
saddlebagged
custom made supports
tool bag
extended backrest
Protac backrest
Highway pegs
custom mirrors
custom grips
V&H cruisers
lever covers
DieHard AGM
Kuryakin battery gauge
and LED taillights
marbled
____________________
VROC #27169
Tn VROC #134
www.youtube.com/thetrueliljd
liljd is offline
