battery optimiser option - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 08-02-2015, 04:08 AM Thread Starter
JETHRO's Avatar
hi i have started using a small solar panel to keep my battery topped up you can use them for all vehicles that are left for some time ,works well
Vn 750 A2 1986 rebuilt engine, crank shaft, half casing,shell bearings,con rods,rear cylinder head,oil pump,water pump ,(had ceased bearing rusted up),tie bar upgrade,clutch basket drilled,front cylinder cam chains,toc springs,stator,shaved, rectifier,agm battery,solenoid ,starter motor (used) re-spray ongoing.
JETHRO is offline
post #2 of 4 (permalink) Old 08-02-2015, 04:21 AM
Cool. Let us know how it works out
post #3 of 4 (permalink) Old 08-02-2015, 11:37 AM
I used one on my Ranchero that I purchased from Harbor Freight. Problem was that it did not ever sense the state of charge and stop charging. It boiled that acid plate battery dry. I finally put it on the shelf with my other not so good investment tools from HF. Usually though I have good luck with most of what I purchase there. Check the manual on yours to see if it maintains the charge or charges constantly. They are a great idea for free energy to use as a trickle charger.
No Brain - No Pain. I measure a man by the good he does for others, not his mistakes.
Green1 is offline
post #4 of 4 (permalink) Old 08-03-2015, 02:21 AM Thread Starter
JETHRO's Avatar
i am suprised to hear that. I use mine because i have no electricity supply close and i had to run out an extension lead ,been using the solar panel for about 2-3 month with no problems it is usually left for a week at a time and then i use the bike weekends
JETHRO is offline
