Starter Relay Question. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 07-12-2015, 05:00 PM Thread Starter
Smile Starter Relay Question.
My bike just suddenly didn't want to start right up on this 90+ degree day. Seems like the relay just wants to click and once in a while let her try to start. Any info on this would be great and also is there a prefered replacement for this part as there is with many discussed on here.
Thank you.
Kristoco.
Kristoco is offline
post #2 of 7 (permalink) Old 07-12-2015, 05:27 PM
can you bypass the relay by putting a screw driver between the posts and make the bike start?
post #3 of 7 (permalink) Old 07-12-2015, 06:01 PM
check battery and connections.. batteries will fail suddenly in high temps
post #4 of 7 (permalink) Old 07-12-2015, 06:03 PM Thread Starter
I did cross them for a second and it tried to turn over. What's that mean?
Kristoco is offline
post #5 of 7 (permalink) Old 07-12-2015, 09:12 PM
The solenoid is bad.
'99 VN750, all stock
performed driveshaft maintenance
checked the ACCT using the Grambo Trick
Sycned carbs with flow meter
Yuasa YTX14AHL-BS AGM Battery
NGK DPR7EIX-9 Irridium Spark Plugs
vulcan1999 is offline
post #6 of 7 (permalink) Old 07-16-2015, 02:17 AM
Sock's Avatar
I got one on Amazon pretty cheap. I think it was around $12, but I could be wrong. I got one for the ATV around the same time and I can't remember what either cost.
1991 VN750, purchased 5/5/15, 9092 miles
Sock is offline
post #7 of 7 (permalink) Old 07-16-2015, 08:01 AM Thread Starter
Well I ordered one and also tore apart the electrics and cleaned every connection. Fires right up yet old solenoid still has a slight clatter. Thank you guys!
Kristoco is offline
Tags
relay , starter relay
