Need help with my 1990 Vulcan Snellville,GA - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 06-24-2008, 04:19 PM Thread Starter
Exclamation Need help with my 1990 Vulcan Snellville,GA
I bought the bike 2 months ago and have just go insurance and license. Pryor to this I just rode the bike around my subdivison. I now have neen ridding it everyday for the past 5 days. 2 days ago I went to crank it was dead. I roll started it and went to the auto parts store and got a new battery. The auto parts store put a quick charge on the new battery and installed and worked great. Last night I was on my way home and noticed that when I turned on my blinkers my headlight blinked as well. Got home and tried to crank it back up and it was dead. I again roll started it and it cranked. Please help. I am pretty mechanicly inclined but not so much with the electrical.
newrider2326 is offline
post #2 of 8 (permalink) Old 06-24-2008, 07:47 PM
did the headlight blink, or did it dim in sync with the turn signals? Check your charging system. (look at the threads that deal with the R/R and stator....as these are your two biggest issues.... ) did you get a MF Battery?
post #3 of 8 (permalink) Old 06-24-2008, 11:29 PM
Sky Rider's Avatar
MF equals maintenance free, not something else.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #4 of 8 (permalink) Old 06-25-2008, 02:42 AM
oglejust's Avatar
o thats what that means .... lol jk put a voltmeter (dmm) on dc volts and put it on the battery w/ the bike running, u should be around 13.6-14.5v if not ur charging is messed up
.... slightly modified
oglejust is offline
post #5 of 8 (permalink) Old 06-25-2008, 08:21 AM
A quick charge isn't a way to get a full charge into a battery.
The slower the charge, the more complete the charge.
And like it's been said, a maintenance free battery is the best way to go!!
post #6 of 8 (permalink) Old 06-25-2008, 01:58 PM Thread Starter
stator
I checked the volts going into the regulator from the stator and comming out of the regulator. The volts going into the regulator from the stator showed 7.4 volts. Comming out of the regulator was 3.6. The problem with the headlight and the brake light blinking was due to the previous owner doing shalty wiring. I rewired the light last night with correct connectors and all is well with the lights. My book says that there could be corrosion in the connecters but I didn't see any.
post #7 of 8 (permalink) Old 06-25-2008, 02:22 PM
Were you checking AC volts, not DC?
You need to check AC. The 7.4 isn't good if it was.
post #8 of 8 (permalink) Old 06-26-2008, 12:03 AM
Sky Rider's Avatar
Voltage coming from stator=AC Should read about 50 volts or so depending on RPM.
Voltage coming from R/R= DC. Should be anywhere from 12.90 to 13.26 or so at idle and 14+ at higher RPM.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
21480 Miles
VROC #8542
