Tuxedo mod question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 07-03-2015, 06:41 PM Thread Starter
'03 VN750 "Rosie"
bstew7890's Avatar
Tuxedo mod question
So it's stator time. It's not charging and a test light shows a ground connection on each of the 3 yellow wires. I was debating either doing the tuxedo mod so I can replace the next one easily, or getting a TPE stator and not having to worry about replacing it in the next 30,000 miles. Then I thought of this: will I be able to change out either the balance dampers or the shift-shaft seal without pulling the engine anyway?
Your input is appreciated!
'03 VN750 "Rosie"
Purchased in June 15, 2010
Lubed Splines
Lubed and Adjusted Clutch Cable, Throttle Cables.
Relocated Voltage Regulator
Brakes Bled
Luggage Rack
Lazy Rider Bag
Leather Saddle Bags
Legitimate Title!! (finally!) Aug 30, 2010
New AGM Interstate Battery Sept 15, 2012
2008 Hyosung GV250 (sold!)
bstew7890 is offline
post #2 of 4 (permalink) Old 07-04-2015, 03:37 PM
Concert connoisseur
wib714's Avatar
no you can not do the dampers without pulling the engine
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #3 of 4 (permalink) Old 07-06-2015, 07:55 PM Thread Starter
'03 VN750 "Rosie"
bstew7890's Avatar
Thanks wib!
post #4 of 4 (permalink) Old 07-06-2015, 10:01 PM
I removed the rear wheel to make it easier to install the engine, without removing the beveled gears.
