Turn signal blinks fast - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 07-03-2015, 03:54 PM Thread Starter
h2ok9's Avatar
Hi All,
About a week ago my right turn signal quit working and the relay was cycling much faster than normal. The amber turn indicator light was blinking fast but neither rt turn light illuminated. After checking the bulbs and found them to be good, I pulled the seat and found a wire to the rt rear directional pulled out of the spade quick disconnect. I replaced the connectors with new ones for a solid connection, problem solved. Today the right turn signal started blinking fast again only differently than before. The rear blinker flashes with normal brightness but the front blinker flashes about half as bright as normal. Do you think it's a bad conection to the front or possibly a directional relay going bad? Thanks in advance.
h2ok9 is offline
post #2 of 3 (permalink) Old 07-03-2015, 08:25 PM
JM2001's Avatar
Originally Posted by h2ok9 View Post
Hi All,
Could be a bad connection, bad flasher, or a bad filament in the bulb. The rear bulbs are 1156 single filament because they are directional only. The front bulbs are 1157 dual filament because they are directional and running lights. The directional filament ( the brightest ) might be bad.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #3 of 3 (permalink) Old 07-06-2015, 01:26 PM Thread Starter
h2ok9's Avatar
I found and fixed the problem. I should have stuck to my KISS method of maintenance (Keep It Simple Stupid). I took out the front right directional bulb and cleaned the two round lead contacts on the base. There was a little micro corrosion on the lead. Reinstalled with good contact, operation normal. Thanks jm2001 for your input.
h2ok9 is offline
