black spark plugs - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 22 (permalink) Old 07-02-2015, 07:16 PM Thread Starter
black spark plugs
Ok my spark plugs are black after about 30 minutes or less running. I have just replaced them and then cleaned them now twice. I think I am running rich but wanted someone to verify before I messed with my adjustment on the carbs.
If I am not mistaken unscrewing the adjuster is allowing more air in, correct?
Grace and Peace to you!
Richard
mrseedsower is offline
post #2 of 22 (permalink) Old 07-02-2015, 07:30 PM
looks rich to me, but I am not a carb guru like some others. I would wait for their feedback
post #3 of 22 (permalink) Old 07-02-2015, 07:35 PM
The "air screws" is a misnomer....they are in fact "fuel enricher screws"...screwing them out adds more fuel, screwing them in makes it leaner.
post #4 of 22 (permalink) Old 07-02-2015, 08:53 PM
Crowley
crowley1027's Avatar
Turn each screw in 1/2 and run. Look at your plugs. If they are still pretty black, go down a pilot jet size.
Just my opinion
crowley1027 is offline
post #5 of 22 (permalink) Old 07-02-2015, 10:26 PM
JM2001's Avatar
Look at the poor condition of the plugs. There is no center electrode left in the plug on the right. The gap is about twice as wide as spec ( .035 ). Until you get good plugs you can't tell if you are running rich or lean.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #6 of 22 (permalink) Old 07-02-2015, 11:34 PM
Crowley
False... I can clearly see the electrode...
And unless you measured the gap in the picture, and had reference measurements, I doubt you can eye that gap.
post #7 of 22 (permalink) Old 07-02-2015, 11:39 PM
JM2001's Avatar
Get a pair of new glasses. That is an old worn out plug.
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #8 of 22 (permalink) Old 07-03-2015, 09:35 AM
Crowley
You are correct. Apologies.
post #9 of 22 (permalink) Old 07-03-2015, 06:27 PM Thread Starter
actually that is the way they came out of the box. The electrode looked just like it did the day I put them in except they are black. I only have about a hour running time on the spark plugs. The gap is also right at .35
I will do the adjustment and see how it turns out.
Richard
post #10 of 22 (permalink) Old 07-03-2015, 06:50 PM
Those aren't iridium plugs are they?
