Source for electrical connectors??? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 06-22-2008, 01:01 PM Thread Starter
Question Source for electrical connectors???
I have found a couple of broken ones. Only one half or the other needs replacing. Does anyone know a source for replacments that will fit with stock? Or should I replace the whole connector? If so does anyone have suggstions on replacement source. thanks 3z
jmczzz is offline
post #2 of 3 (permalink) Old 06-22-2008, 02:02 PM
Radio shack, Walmart, Hardware store. Many places will have electrical connectors of all sorts.
I'd suggest replacing both male & female sides with connectors made for each other to assure a good fit/connection. And be sure to get ones made for the wire size you're working with.
post #3 of 3 (permalink) Old 06-23-2008, 06:29 PM
darrelc5's Avatar
The OEM-style connector inserts for our bike are typically not available at local hardware stores. I have ordered inserts for about every connector from Eastern Beaver and this place seems to have a lot also: Cyclewareables. I recommend buying the correct crimper for the job to assure long lasting joints.
Darrel
'03 Vulcan 750 (90k miles)
-Corbin Seat
-V-Force Windshield
-LeatherLyke Touring Bags
-Chrome Luggage Rack
-Headlight Modulator
-Brakelight Flasher
-MF Battery
-Heads-Up Voltage Monitor
-Replaced Stator (9,000 and 16,000 mi.)
-Oil-cooled Stator Mod (photos)
-Replaced and Relocated R/R
-Greased rear splines
-Fused Stator (photos)
-Metzeler ME880 Marathon 170/80-15 (Rear), 110/90-19 (Front)
-TOC MCCTs installed
-Headlight Relays
SOLD - 2013
darrelc5 is offline
