stator and rectifier resistance a smidge low - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 19 (permalink) Old 06-20-2008, 06:00 PM Thread Starter
Hi, my 86 750 is reading .2 on a stator test. Normal is .34 -.4???? Is this low enough to warrant replacing it? Hate to spend the money if it's not needed. Same deal on the resistance test on the rectifier just a smidge low. Thanks
cagillis is offline
post #2 of 19 (permalink) Old 06-21-2008, 02:51 AM
what is your charging output voltage? Also check all connectors for corrosion very carefully...i found that to be the problem with mine.
post #3 of 19 (permalink) Old 06-21-2008, 09:11 AM Thread Starter
Output voltage rarely hits 13 - 13.5 volts
cagillis is offline
post #4 of 19 (permalink) Old 06-21-2008, 11:40 AM
On His Lady Vulcan
wkrizan's Avatar
The resistance part is fine but like Slim stated make sure your run all the other tests before you come to your conclusion.
Peace
Pictures of the "Ladies"
wkrizan is offline
post #5 of 19 (permalink) Old 06-21-2008, 01:22 PM
your numbers all seam fine...what is the bike doing to make you think it is not charging?
post #6 of 19 (permalink) Old 06-21-2008, 08:15 PM Thread Starter
If I charge the battery full I can start and ride all day. I did notice that one a lenghthy ride when I shut it off the starter will barely turn over. It happened today then we went out for a while when I got home it started right up once it cooled down. Seems to me like maybe a breakdown somewhere when it gets hot. R/R perhaps?
cagillis is offline
post #7 of 19 (permalink) Old 06-21-2008, 09:55 PM
Sky Rider's Avatar
Do you have a Maintenance Free battery?? It almost sounds like you have an old battery or a wet cell that is low on electrolyte. Heat can cause the symptoms you give with a worn battery or one low on fluid. Either situation is not good for the charging system.
I wouldn't worry too much about the resistance readings yet. My first concern would be the battery. I'd get it load tested to see if it's up to snuff. Most auto parts stores will do this for you.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #8 of 19 (permalink) Old 06-22-2008, 01:10 AM
On His Lady Vulcan
wkrizan's Avatar
If you are still running with the old wet cell battery do yourself a HUGE favor and pick up a M/F right away. Solves 98% of hot start probs. Wally World even carries them so no excuse not to have one. Theres one on every other block anymore...lol.
Peace
wkrizan is offline
post #9 of 19 (permalink) Old 06-22-2008, 08:16 AM Thread Starter
I just put a brand new wet cell in last week when I got the bike. Kawai dealer recomended wet cell. I had a bad feeling when I replaced an old MF with a wet cell. Old MF would not even take a charge.
cagillis is offline
post #10 of 19 (permalink) Old 06-22-2008, 08:56 AM
Tcat1000's Avatar
Battery
HUH?......Your dealer recommended a wet cell over a MF? I would be looking for a new dealer!
Remember the commercial a few years ago where it stated that if you weren't happy with your new tires on your car----feel free to return them. Then you saw an old lady pitch one through the front window of the tire dealer?
Hmmmmm..............For some reason that commercial seems to come to my feeble mind reguarding that wet cell battery..........
Tcat
2006 VN750
Splines lubed With TSMOLY 70
R&R Relocated
Marbled (Cat's eyes no less)
Digital Volt, Amp, Temp gauge (Kisan)
Pipes Drilled
Carb Adj. at 3 3/4
Polaris AGM Battery (190 CCA)
Kaw rear rack
Kaw front engine guard
National Cycle Street Shield EX W/S
Mobile 1 MX4T 10W40 oil (Now labled 4T Racing)
Purolator PL14610 oil filter (Painted)
Iridium Spark Plugs
Pulsating Brake Light (Kisan)
My Motto: Don't get mad, just get even. Trust me, I will get even!
Tcat1000 is offline
