tach bounces or does'nt work at all - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 06-16-2008, 06:37 PM Thread Starter
My 86 seems to have a tach problem. When the engine is running the tach bounces around or most of the time doesn't work at all. Any suggestions? Thanks
cagillis is offline
post #2 of 10 (permalink) Old 06-16-2008, 07:48 PM
San Diego Vulcan Rider
DeForestSD's Avatar
Good luck. This seems to be an issue that has no definitive answer. I have an 86 with the same problem. The most common suggestion is to check all the connections but I still don't know for sure where all those connections are. I think someone once said they cleaned the nylon connector contacts in the headlight bucket and fixed it but don't quote me. As for me, my tech skills are terrible and my bike runs great so I'm hesitant to go poking around and maybe do some serious damage. The tach issue is probably not one so critical that one of our experts would do a pictorial (like Fergy's spline procedure) showing how to trouble shoot. But I'm still praying.
86' Vulcan, Stock & Lovin it!
Stator, R/R, splines lubed, ACCT's repl. at 25,200
Just turned 29,000 mi.
95' Vulcan, all stock, 9,700 mi.
John Spangler
DeForestSD is offline
post #3 of 10 (permalink) Old 06-16-2008, 08:51 PM
HAWK
Ccspinner's Avatar
I would start with checking the grounds.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #4 of 10 (permalink) Old 06-16-2008, 09:08 PM
liljd's Avatar
a jumping tach means only one thing, the signal has been corrupted or bad tach which would mean two things LOL. The fix...clean ALL contacts with a plastic safe cleaner. If that does not work you'll need to trace the short down and replace the wire. Do you have the notirious squeel that accompanies the jump??
James
1985 vn700 (T'Plana)
Gremlin bell
HD-O shield
saddlebagged
custom made supports
tool bag
extended backrest
Protac backrest
Highway pegs
custom mirrors
custom grips
V&H cruisers
lever covers
DieHard AGM
Kuryakin battery gauge
and LED taillights
marbled
____________________
VROC #27169
Tn VROC #134
www.youtube.com/thetrueliljd
liljd is offline
post #5 of 10 (permalink) Old 06-16-2008, 10:55 PM
The tach runs off of (I'm pretty sure) the front cyl. coil black wire.
Check and clean the connection and see if that helps.
post #6 of 10 (permalink) Old 06-17-2008, 11:36 AM
Hi Cagillis
Does the bike run ok when the tacho is playing up (misfiring, running on one cylinder)?
If it does then you could well be having problems in the wiring from the ignitor to the coil, or the ignitor itself. The tacho gets the pulses that the ignitor sends to the front ignition coil (located on the left hand side under the tank). A wire then goes from the ignition coil to the tacho). Mine does it occasionally, but the bike runs fine, just got to find the time to pull apart all the connectors and clean then up. I use a Dremel with a fibre glass/plastic brush to get rid of the deposits on the male connector and then pull and push the connector on to clean the female. Squirt of contact cleaner and wrap up in rubber amalgamating tape.
If the bike runs fiine when the tacho is playing up, then it has to be in the wiring from the tacho to front ignition coil, the tacho or the power supply to the tacho.
One other little one is the tacho power comes through the ignition switch, so that could be another culprit. If you look at Page 15-42 of the Kawasaki manual there are three wires that go to the tacho unit:-
BR - Brown (+12v from the ignition switch)
BK/Y - Black/Yellow (Earth)
BK - Black from the Front Igniotion Coil
One of those should be the problem if the bikes running ok.
Hope this helps and good luck.
DaveT
Kuala Lumpur
davet is offline
post #7 of 10 (permalink) Old 06-23-2008, 11:48 AM
DeForestSD's Avatar
Just wondering if you ever solved the problem? If so, what did you find was the problem? Thanks.
John Spangler
post #8 of 10 (permalink) Old 06-25-2008, 07:22 AM Thread Starter
I cleaned all the connectors and yes I do have the squeel. still no tach
cagillis is offline
post #9 of 10 (permalink) Old 06-25-2008, 08:00 AM
still no tach
Well, it's possible with the bike being 22 years old, the tach has seen better days.
I'm not sure how you could test the tach, but keep an eye here or on ebay or maybe even scrap yards for a used one cheap.
post #10 of 10 (permalink) Old 03-12-2012, 08:00 AM
Steve
350ernie2's Avatar
Hi I have the same problem. I wil check teh front coild conenction first, but all the headlight wires appear to be ok. I ahev the 86 750a . remarkable bike, after all tehse years. .Remionds me of my forst raod bike which as was teh LTD 250. Relaxed ride but now with 750 power. True sense of crusing, and really good value .
Steve
VN750
KH500
Ducati 350sss
350ernie2 is offline
