vulcan 750 battery - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 06-13-2015, 10:41 AM Thread Starter
vulcan 750 battery
I'm going to do the pick up coil modification on my 750. I'm told I will need a 400cc battery. What size battery--L x W X H will fit so I can pick it up , or might have to order it.The bike is a 2005 kawasaki vulcan 750. I also triked it out.Thank you in advance.
Dean Hasty is offline
post #2 of 3 (permalink) Old 06-13-2015, 11:34 AM
no need to upsize the battery for the pick up coil mod, or any mod that does not put additional electrical load on the system.
I have done it, using the AGM replacement for the stock battery (I believe its around 220 CCA) with no problems at all.. so have many others
michiganteddybear is offline
post #3 of 3 (permalink) Old 06-13-2015, 01:07 PM
Compatible AGM Batteries
Manufacturer Model CCA . . . Availability. . . Additional Notes
YUASA YTX14AHL-BS AGM Battery BatteriesPlus
X2-15L 210 BatteriesPlus Deka ETX15L re-branded- - $95.00 Store-Nov-2012
Big Crank ETX15L 210 Online Retailers, eBay Deka ETX15L re-branded --- Ebay - $68.00 Nov-2012
Deka ETX15L 210 Online Retailers, eBay
Die Hard 44005 210 Sears YUASA YTX14AHL-BS re-branded $80.00-Store Nov-2012
EverStart ES14AHBS 210 Walmart Terminals are swapped, so install backwards and remove bottom spacer. UPDATE: Dec 2012 = $89.99
Interstate CYTX14AHL-BS 210 Retailers YUASA YTX14AHL-BS re-branded
MagnaPower ETX15L 210 Advance Auto Parts Deka ETX15L re-branded -
Manga Power 12v Sealed AGM 220CCA ($81.99 – April 2013)
WestCo 12V14L-B 220 WestCo
YUASA YTX14AHL-BS 210 Online Retailers, eBay $78.00 online Dec-2012 ----$88.00 Dec-2012
Magma Power ETX15L 220 CCA Advance Auto Parts 220 CCA $77.00 - Online -Take 15% off -Enter code DEM11 at checkout. Online Only.
Scorpion YTX14AHL-BS Scorpion 12v 210 CCA AGM BatterieStuff.com $66.00 + Sert 2013 BatteryStuff Part #: sYTX14AHL-BS Replaces: YTX14AHL-BS, YB14L-A2, YB14L-B2, 12N14-3A,CB14AL-A2
NOTE: Ebay / Online prices quoted above are from a single online 2012 search, additional search’s may produce different prices.
