Instrument bezel rework - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 06-15-2008, 12:48 PM Thread Starter
Vulcan Traitor ;)
Send a message via Yahoo to Keemez
I was going to post this in line with my LED aux lights install, but it's a separate issue so I'll do a new thread altogether.
I took delivery of my motor just before Memorial day, so I'm pretty new and green to this model yet. But I'm also pretty fond of it so far. I've done far more putzing with this bike than I've ridden it in the few weeks it's been in my possession, but that's ok because I'm still waiting on the DMV to mail me my license plate. Plus it's given me the chance to give it a thorough go-over, clean things up, make mods, etc. One of the obvious things that needed attention was the rusty / pitted trim rings around the instruments. I wasn't sure how to best go about that, so I took it slow. This is what the tach originally looked like: https://www.vn750.com/photopost/showp...o=1611&cat=501
After I got everything all disassembled, I went to work with a small stainless wire wheel on the Dremel, which took away some of the loose stuff but left some pretty good pitting and the appearance was still kinda junky: https://www.vn750.com/photopost/showp...o=1612&cat=501
I tried lightly hitting them against the wire wheel on my grinder, but that didn't do much good and only ate away at the plating and into the potmetal underneath which is semi copperish bronze-ish in color. So I taped the critical surfaces and got busy with the glass media bead blaster at work, which largely (but not completely) negated the pitting and left a good surface ready to be painted. Here you'll still be able to see the discoloration from where I wire wheeled on the grinder:
https://www.vn750.com/photopost/showp...o=1613&cat=501
https://www.vn750.com/photopost/showp...o=1614&cat=501
I retaped, primed with self etching primer, then used a satin black off-the shelf spray can of paint from Autozone and put on a number of coats. Light coats at first, then a little heavier to sort of smooth out the end finish. And here's what I wound up with, all reassembled and reinstalled:
https://www.vn750.com/photopost/showp...o=1610&cat=501
https://www.vn750.com/photopost/showp...o=1609&cat=501
https://www.vn750.com/photopost/showp...o=1608&cat=501
Not bad, eh? I'm amateur at best when it comes to painting and critical bodywork/reconditioning, but I'm pretty pleased with how this looks. I'll be sure to keep a polished coat of wax on these babies from here on out.
Keemez is offline
post #2 of 14 (permalink) Old 06-15-2008, 02:11 PM
Nice work, I also painted the upper fork clamp black:
http://tinyurl.com/67v4aq
post #3 of 14 (permalink) Old 06-16-2008, 10:18 AM
Search Goddess
Dianna's Avatar
I LIKE the black rings on the gauges. A nice satin or matte black blends well with the bike AND.. it also cuts down on anything that might reflect and blind you.
Nice job on the prep and paint!
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #4 of 14 (permalink) Old 06-16-2008, 10:29 AM Thread Starter
Vulcan Traitor ;)
Thanks! It dang well better look good, considering the amount of labor I put into it. Several hours, to be sure.
Keemez is offline
post #5 of 14 (permalink) Old 06-16-2008, 10:48 AM
dirtrack650's Avatar
Therapy Keemez, shop time is good for the mind. It is very nice.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #6 of 14 (permalink) Old 06-16-2008, 11:42 AM
ChrisC's Avatar
Very Nice! I went with the flat black, but I like the look you wound up with.
Chris
Wayne, NJ
1989 VN750-A5
VROC #27781
-MF Battery
-De-Goated/Re-goated
-Coastered
-Splines Lubed
-Stebel Nautilus Horn
-AutoMeter 2" VOM
-Silverstar Headlight
-Plexifairing III
ChrisC is offline
post #7 of 14 (permalink) Old 06-16-2008, 12:16 PM Thread Starter
Vulcan Traitor ;)
Originally Posted by dirtrack650 View Post
Therapy Keemez, shop time is good for the mind. It is very nice.DT
Wait...which do you mean is very nice? Therapy, shop time, or the mind? Or all three? Or none of the three? Some combination of two of the three?
Keemez is offline
post #8 of 14 (permalink) Old 06-16-2008, 03:12 PM
Heheheheh...Therapy is my 750; she's a sweetheart, and she and shop time are good for the mind. (Cycletherapy and shoptherapy <G>)
Nice job on the instruments, dude; look really good!
Jim
J.D.
Kerrville, TX
'95 Vulcan 750 "Therapy II",
aka "Raggedy Ann"
'95 VN750 project
'03 VN800B "The Little Black"
'04 VN800E Drifter project
'93 VN1500A custom project
VROC #16185
GCVROC #33
J.D. is offline
post #9 of 14 (permalink) Old 06-16-2008, 06:12 PM
750Doug's Avatar
Nice job, they look pretty good.
750Doug is offline
post #10 of 14 (permalink) Old 06-17-2008, 12:14 AM
YOu did an awsome job...I hope mine turn out half as good as yours did.
