stator r/r & battery replace all? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 06-13-2008, 09:28 AM Thread Starter
The advice / info from the forum has helped get the carbs clean and the bike is running much better. Is the next step is to adjust sync, or solve the charging problem? Or go ahead pull/tilt engine and do both?
I'm not sure I need to change the stator, r/r and battery, except I know my bike is not charging. The battery is a wet cell; PO said it was "new". I relocated the r/r it appears to be original or at least old. I hooked an analog vom to the battery at 1k rpm approx. 12 -13 volts, rev up to 4 - 5k no change. The bike will not start without the battery charger on, when running it gets rough when I disconnect the charger, and the volts drop a little.
Should I go ahead and pull/tilt engine and take a look and plan on changing the stator, the r/r and get a new MF battery? I am not diagnostician, just a parts changer, unless someone can suggest different I will plan to change out all 3 items mentioned above.
Also there seems to be some choices as to what products to use. Rick has; stator, $140, r/r $100, and I read in the forums about 2 MF battery choices both about the same price. Electo… has a stator, $119, no r/r listed, but I also read about oem r/rs from Bike Bandit etc. Why the significant price difference?
Also a forum member has a known good used stator for sale for about $50.00 less, is this a good choice?
thanks 3z.
jmczzz is offline
post #2 of 7 (permalink) Old 06-13-2008, 01:32 PM Thread Starter
Thanks to whrizan I now have the Electrosport fault finding chart in hand. today I will try to be a bit more systematic about finding out whats up!
thanks for tolerating my ignorance.
3z
jmczzz is offline
post #3 of 7 (permalink) Old 06-13-2008, 02:01 PM
Take the battery to an auto parts store to have it load tested.
As many have said here, many times, even a new battery can be junk.
I wouldn't think about a stator change until all other options are dealt with first.
post #4 of 7 (permalink) Old 06-13-2008, 03:01 PM
Now what
Ironman's Avatar
I'd follow the fault finding chart to know where the problem is. You could replace the stator and the R/R just to find you didn't fix the problem and ruin one or both of the new, expensive and hard to replace parts. That might just push you over the edge. (or at least you might push the bike over an edge)
'04 750A- and loving it!
VROC 13864
Using a Purlator One PL14610
Ironman is offline
post #5 of 7 (permalink) Old 06-13-2008, 07:45 PM
On His Lady Vulcan
wkrizan's Avatar
3z
Hey man my pleasure, anything that I can do to help out another Vulcan Brother/Sister.
Peace
Pictures of the "Ladies"
wkrizan is offline
post #6 of 7 (permalink) Old 06-14-2008, 04:16 PM Thread Starter
Help! my r/r wires don't follow the guide (see Above) I have 6 wires, 3 yellow, 1 brown and 1 black with yellow stripe and 1 white. Now What!!!
jmczzz is offline
post #7 of 7 (permalink) Old 06-14-2008, 11:00 PM Thread Starter
ok I checked the forum further and found how to test the r/r from the connector. It tested bad. 3z
jmczzz is offline
