charging problem - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 06-08-2008, 10:30 PM Thread Starter
Unhappy charging problem
i have 86 vulcan that don't keep the battery charged i did all the tests they all are good but it still don"t charge. i've notice the ground wires get real hot do they normaly get hot and if not could this be the reason the battery is not charging.
fadro is offline
post #2 of 5 (permalink) Old 06-08-2008, 10:56 PM
kay
carbon unit
kay's Avatar
First check the rectifier. It could be bad..(batteries don't much like receiving alternating current) then try cleaning your ground connections both at the battery and the frame.
And make them tight and clean. If this doesn't help then look for a short (+wire melted and partially touching metal) failing that ...look at replacing the battery (bad cell)
2010 Triumph Speedmaster
1995 Vulcan750
1989 XT350
M880
1959 M38A1
kay is offline
post #3 of 5 (permalink) Old 06-09-2008, 02:17 PM Thread Starter
frist of all thanks kay i thought i did all of the test but i tested r/r ground wire while it was running and it was putting out 5.2 v . but the guy that i bought it from cut the plug wired it individual wires the clymer book i have shows the diagram but witch one is witch a1 a2 a3 iknow them then it has g,m,b on the bottem row is g - ground m - ? b - battery may the guy before me got them backwards .. maybe i shouldn't have bought it but it was just 700$ and it runs good carbs a little dirty but this dang charging problem
fadro is offline
post #4 of 5 (permalink) Old 06-09-2008, 03:13 PM
ChrisC's Avatar
a1,2,3 are the yellow wires from the stator. B, battery, is the white wire. M, monitor, is the brown wire (switched power). G, ground, is the black wire.
Chris
Wayne, NJ
1989 VN750-A5
VROC #27781
-MF Battery
-De-Goated/Re-goated
-Coastered
-Splines Lubed
-Stebel Nautilus Horn
-AutoMeter 2" VOM
-Silverstar Headlight
-Plexifairing III
ChrisC is offline
post #5 of 5 (permalink) Old 06-09-2008, 08:41 PM
Sky Rider's Avatar
A 1,2, and 3 can be plugged in in no particular order as it is 3 phase AC. The R/R smooths this to DC and regulates it for the bike to run and charge the battery.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
