wacky tach - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 05-21-2015, 04:25 PM Thread Starter
wacky tach
ok, starting to get random/intermittent tach issue.. it will go from normal reading and spike UP toward or even past redline, or even hit the stop.
NO change in engine rpm, or missing or anything else... is it just going horseshait, or is there another cause.
michiganteddybear is offline
post #2 of 5 (permalink) Old 05-21-2015, 05:21 PM
JM2001's Avatar
I would check the wires going to the front coil for corrosion or a bad connection.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #3 of 5 (permalink) Old 05-21-2015, 07:27 PM
heaney750's Avatar
bad ground on the tac would be my guess
heaney750 is offline
post #4 of 5 (permalink) Old 05-22-2015, 09:55 AM
Check your battery terminals too, pull the seat and make sure they're tight.
post #5 of 5 (permalink) Old 05-22-2015, 10:35 AM
x2 on connections. Mine did the same when the negative on the battery can loose.
