wire placement? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 05-16-2015, 11:43 PM Thread Starter
dgulley21's Avatar
wire placement?
Ok got a new r/r and actually found a new replacement 6 pin connector. Moved the r/r and comparing wiring placement in the connector and images I can find online have me confused about wire positioning in the connector! I am cool w the the stator wires it's the ground, battery and monitor wire and their proper position in the connector or does it even matter??
dgulley21 is offline
post #2 of 9 (permalink) Old 05-16-2015, 11:56 PM
It matters...
Only one I remember is the brown was in the middle (double check that). Should be some pics here somewhere.
Someone will post the answer soon I bet. Just wanted to post that it does matter where those wires go.
post #3 of 9 (permalink) Old 05-16-2015, 11:59 PM Thread Starter
dgulley21's Avatar
Thanks I have the connector I took off and then I see pics on here that are conflicting but brown in the middle on all.
post #4 of 9 (permalink) Old 05-17-2015, 08:28 AM
JM2001's Avatar
If you bought a Mosfet regulator you do not use the brown wire. Just put a wire nut on and tape it.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #5 of 9 (permalink) Old 05-17-2015, 09:14 AM Thread Starter
dgulley21's Avatar
Had the bike looked at locally before I found you all and recommended a r/r from Rick's and it looks like oem part so I found a connector just need proper wire placement?
post #6 of 9 (permalink) Old 05-17-2015, 01:22 PM
Might be looking at mine in a little while and I can check, if you still need it. Have a mosfet but the stock plug is still dangling somewhere.
Waiting to hear back from someone wanting a pattern for an r/r bracket I made. Could send one to Crowley so he can start making those too.
post #7 of 9 (permalink) Old 05-17-2015, 05:39 PM
heaney750's Avatar
black and yellow on the left brown in the middle white and yellow on right all on the bottom 3 yellows on the top i just popped off my side cover to look i have an oem one on my bike
heaney750 is offline
post #8 of 9 (permalink) Old 05-17-2015, 06:27 PM Thread Starter
dgulley21's Avatar
Ok good that's what I got!
post #9 of 9 (permalink) Old 05-17-2015, 07:51 PM
Wink
Lol, have my side cover off and came back in to get a flashlight, stuffed that old plug back where I can't see it.
