Not sure this is electrical-but speedometer cable fell off - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 18 (permalink) Old 05-14-2015, 09:21 AM Thread Starter
BeeSea's Avatar
My cable came off and I bought a new one, although the old one seems to not be broken, but since it fell off during a ride I decided to replace it but does it need to be oiled? The old one seemed pretty dirty and may have had oil on it. I can't find anywhere anything about it so I have screwed the new one in-but before I take her out for a spin thought I would check with you guys. If it does need oiled what type and how much do you put in?
thanks,
BeeSea
1986 750 Vulcan
Relocate R/R to side cover
Re-did the engine
from the case up.(And it runs)
YOU CAN TOO!
BeeSea is offline
post #2 of 18 (permalink) Old 05-14-2015, 11:59 AM
Exclamation
Originally Posted by BeeSea View Post
My cable came off and I bought a new one, although the old one seems to not be broken, but since it fell off during a ride I decided to replace it but does it need to be oiled? The old one seemed pretty dirty and may have had oil on it. I can't find anywhere anything about it so I have screwed the new one in-but before I take her out for a spin thought I would check with you guys. If it does need oiled what type and how much do you put in? thanks,
Speedo cables come from factory with pre lubed minimumly (sp).....
If you do attempt to add lube to cable, DO NOT utilize a thin lubricant such as WD40.
....hope this helps
WilliamTech
post #3 of 18 (permalink) Old 05-14-2015, 12:29 PM
Crowley
crowley1027's Avatar
....hope this helps
WilliamTech
Minimally
crowley1027 is offline
post #4 of 18 (permalink) Old 05-14-2015, 12:30 PM
Crowley
Don't worry about lube. If it needs lube it should already have it.
post #5 of 18 (permalink) Old 05-14-2015, 12:44 PM Thread Starter
BeeSea's Avatar
Ok thanks.
BeeSea
1986 750 Vulcan
Re-did the engine
YOU CAN TOO!
BeeSea is offline
post #6 of 18 (permalink) Old 05-14-2015, 01:00 PM
Speedo cables require grease....as they turn. Other pull cables only need a light coating of oil. (Like 3+1 oil, not WD40)
I use general purpose bearing grease on the speedo.
post #7 of 18 (permalink) Old 05-14-2015, 01:19 PM
Wd40 isn't a lubricant...I wish more people realized that.
If you really want you could get a spray can of lithium grease and spray down into the sleeve, but you shouldn't have to worry about it.
post #8 of 18 (permalink) Old 05-14-2015, 01:40 PM
+2 on the lithium. Not x2 cause I just want to be different today.
post #9 of 18 (permalink) Old 05-14-2015, 02:32 PM
X5 on the lithium as cause I had a conference with 2 of the guys in my head as well
post #10 of 18 (permalink) Old 05-14-2015, 10:03 PM
Yes Angell WD40 is not a lube, the WD stands for Water Displacer. It is used to dry electrical parts.
smltownr is offline
