jumping voltage - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 05-09-2015, 06:49 PM Thread Starter
FastHamFreddy
FastHamFreddy's Avatar
jumping voltage
New stator new R/R voltage is jumping from 12-18v , ive cleaned all ground contacts. anything else I should be checking? Ive read something about checking the "sense" wire should I and where is it.
FastHamFreddy is offline
post #2 of 5 (permalink) Old 05-09-2015, 07:29 PM
Crowley
crowley1027's Avatar
I think it's the brown wire? Coming off the r/r.
Is yours mosfet or stock style?
crowley1027 is offline
post #3 of 5 (permalink) Old 05-09-2015, 07:49 PM
yea, more info on what you have going there is needed to really give a direction.. but 18v is way too much.
post #4 of 5 (permalink) Old 05-09-2015, 08:04 PM Thread Starter
FastHamFreddy
.07 resistance between each yellow wire. And 22.2 volts ac while running between yellow wires. It's stock. New aftermarket r/r oem
post #5 of 5 (permalink) Old 05-09-2015, 08:39 PM
JM2001's Avatar
Stator should put out over 70 volts ac. Must have a bad r/r to be putting out 18 volts.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
