jumping voltage - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 05-09-2015, 06:39 PM Thread Starter
FastHamFreddy
FastHamFreddy's Avatar
jumping voltage
New stator new R/R voltage is jumping from 12-18v , ive cleaned all ground contacts. anything else I should be checking? Ive read something about checking the "sense" wire should I and where is it.
FastHamFreddy is offline
post #2 of 3 (permalink) Old 05-14-2015, 08:43 AM
BeeSea's Avatar
I also have an old bike (1986) and wires were pretty beaten up. The negative ground needed replacing and I originally replaced my R/R with a non-mosfet R/R. BUT it failed and pretty quickly too. I would go back and recheck your new parts and make sure you have correct readings. (i.e. The new parts are working.)
BeeSea
1986 750 Vulcan
Relocate R/R to side cover
Re-did the engine
from the case up.(And it runs)
YOU CAN TOO!
BeeSea is offline
post #3 of 3 (permalink) Old 05-14-2015, 12:42 PM
Where is your voltmeter connected?
