Wiring issue - some lights work, some don't. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 05-06-2015, 06:42 PM Thread Starter
Crowley
crowley1027's Avatar
Front turn signals blink but do not stay solid. Headlight works normally. No tail light (running or brake, from either sensor). Plate light also out. Speedo light also out.
Shrink wrapped the two wires under tank left side (bullet connectors by the bracket) after I saw one spark against frame. No fuses in now (bought new ones), but will see what they do.
Harness to frame is grounded, battery to frame, engine to frame.
crowley1027 is offline
post #2 of 6 (permalink) Old 05-06-2015, 08:17 PM
ign switch... or junction box/fuses. about all they have in common.
michiganteddybear is offline
post #3 of 6 (permalink) Old 05-06-2015, 09:01 PM Thread Starter
Crowley
I was thinking Junction box... Don't know how I'd test it though.
post #4 of 6 (permalink) Old 05-06-2015, 09:30 PM
JM2001's Avatar
Check the resistance of the terminals of the junction box for bad diodes.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #5 of 6 (permalink) Old 05-06-2015, 10:40 PM
Check the red wire too.
post #6 of 6 (permalink) Old 05-07-2015, 12:16 AM Thread Starter
Crowley
Update.. I'm disappointed. In myself....
Three wires that go to the tail light were all taped together at the spade connectors, effectively shorting it out. I didn't know this till I plugged the tail light in and blew the tail fuse.
Here's the good part - the tail fuse is used by all aforementioned lights that didn't work. So, new fuse, wires all separated and shrink wrapped, all good.
Stupid me.
