how is the firing produced - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 05-04-2015, 05:42 PM Thread Starter
Ok I know the stater produces the ac voltage to the rectifier/regulator module which keeps the 12-14 volts in the system to charge the battery and keep the lights, etc... running but what produces the firing. The coils intensifies the spark from the 12 volts but what sends the signal to fire. Does the 93 model have points or automatic ignition.
I understand points but not so much automatic ignition.
I have very weak spark but I have weal spark on both coils. Can't understand how two coils could have gone bad unless I have corrosion build up on the coil connections.
Anyone have advice how to troubleshoot the firing.
Grace and Peace to you!
Richard
mrseedsower is offline
post #2 of 5 (permalink) Old 05-04-2015, 06:08 PM
the ignition is electronic.. there are 2 pickup coils (one for each cylinder) that sends a pulse to the ignition module. that in turns fires the coils.
the coils are fed a constant 12v when ign switch is on. the ground side of the coils is switched by the ign module. weak spark can be caused by low voltage at the coils. ign coil mod is the way to go if the voltage at the coils is marginal.
michiganteddybear is offline
post #3 of 5 (permalink) Old 05-04-2015, 11:09 PM
JM2001's Avatar
The IC Ignitor may be your problem. It feeds the voltage to the pick up coils.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #4 of 5 (permalink) Old 05-05-2015, 08:15 AM
Course, it's not like the spark is a blinding flash either. You tried iridium plugs?
post #5 of 5 (permalink) Old 05-05-2015, 11:31 AM
x 2 !
