Side stand switch - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 05-29-2008, 03:23 PM Thread Starter
Side stand switch
My VN750 -93 starts without problems, runs without problems and there are absolutely no problems of shifting gears, but the side stand switch seems to switch of the engine as I want to get out in the streets. As I ease the clutch with a gear in the engine dies, regardless if the side stand is down or up.
1) Is there any possibilities to open and lubricate the switch without destroying the part? (The closest spare switch seems to be in the Netherlands...)
2) Where does the electrical cable from this switch end? I can't see this as it disappears behind the cooler and there are quite a few cables comming up from there to the handlebars.
3) Is there any website where I can find a wiring diagram?
Thanks for helping!
Lollo is offline
post #2 of 9 (permalink) Old 05-29-2008, 05:51 PM
San Diego Vulcan Rider
DeForestSD's Avatar
Try here;
https://www.vn750.com/photopost/showp...ze=big&cat=503
86' Vulcan, Stock & Lovin it!
Stator, R/R, splines lubed, ACCT's repl. at 25,200
Just turned 29,000 mi.
95' Vulcan, all stock, 9,700 mi.
John Spangler
DeForestSD is offline
post #3 of 9 (permalink) Old 05-29-2008, 07:32 PM
Now what
Ironman's Avatar
The side stand switch wire is green with a white stripe and terminates at the junction box. You could try squirting contact cleaner into the switch and see if that helps.
'04 750A- and loving it!
VROC 13864
Using a Purlator One PL14610
Ironman is offline
post #4 of 9 (permalink) Old 05-29-2008, 09:12 PM
Crobins365's Avatar
I don't think so - it is green, but it comes off the side stand (two phillips head screws) and goes up the left hand side of the frame and connects to the wiring harness via a black connector (two-pin). Contact cleaner or dielectric grease might help the contact point, but make sure that the switch coming up off the side stand is moving. PB Blaster or a similar kind of solvent should open it up.
Ironman, are we looking atthe same wires?? I may have the wrong one.
C
Crobins365 is offline
post #5 of 9 (permalink) Old 05-30-2008, 01:00 AM
Now what
Ironman's Avatar
I was going by the wiring diagram in Clymers. I'll have to go out later and take a look at it.
Checked it out. Mine is still covered by shrink tubing so I can't verify it.
VROC 13864
Ironman is offline
post #6 of 9 (permalink) Old 05-30-2008, 01:42 AM
Hello all when i bought my 93 it doesn't have the side stand switch maybe they bypassed it some how . Or i just don't see one on my bike but there should be one
gcgoff is offline
post #7 of 9 (permalink) Old 05-30-2008, 08:17 AM
Crobins365's Avatar
Ah, you've got a newish bike, don't ya? I imagine it is nicely covered at this point - otherwise that wire kinda dangles there along the left frame. I'll try to shoot some pics tonight, see if we're looking at the same things.
C
post #8 of 9 (permalink) Old 05-30-2008, 07:41 PM
Sky Rider's Avatar
You could just cut the wires to the switch and then short them together to bypass it temporarily while you either fix the switch or order a new one.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #9 of 9 (permalink) Old 06-08-2008, 05:21 AM
Straight roads are evil
Originally Posted by Lollo View Post
1) Is there any possibility to open and lubricate the switch without destroying the part? (The closest spare switch seems to be in the Netherlands...)
Don't think you can take it apart, it looks like one unit. Try squirting it with WD40.
If the switch is truly bad, order it from your local Kawasaki dealership. Part 27010-1189 SWITCH,SIDE STAND. They should have it for you in about 3 days.
EQPlayer is offline
