Ok guys 13 volts when cranking - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 05-02-2015, 08:40 PM Thread Starter
My battery is bad but I have put a cranking battery charger on the bike to see if having the correct voltages would produce a blue spark. When I test the battery connection voltage with the charger it is producing 15 volts but once I hit the starter it drops down to 13 volts and also the spark is darker, it is still orange not blue.
Can the spark plugs go bad by just sitting for a few years? Any suggestions where to look next?
Grace and Peace to you!
Richard
mrseedsower is offline
post #2 of 11 (permalink) Old 05-02-2015, 08:50 PM
rsavant's Avatar
It's normal for the voltage to drop when current is drawn. I'd think if the no load voltage is 15v and it drops to 13 when the starter is engaged that's prob about right, since he starter draws a lot of current. What if you disregard the orange spark for now and see if you have other problems, like maybe fuel/mixture? When did the bike run last? Was it running when you got it and is it new to you?
"Katie"
2002 VN 750, stock except for accessories
Mustang seat
Super Bright LED brake strobe on trunk
About 25k miles
All drive train maintenance performed, drive shaft coupler replaced
Way more experienced at pulling VN 750 carbs than I ever wanted to be.
TOC ACCT rebuild kits installed
Pick up coil mod
Cooling system flushed, refilled with fresh coolant
Petcock rebuilt
VN sold, current steed Honda ST 1300
rsavant is offline
post #3 of 11 (permalink) Old 05-02-2015, 09:07 PM Thread Starter
When I got the bike 3 years ago it had sat for a few years before I got it. Just within the last 2 weeks I pulled the carbs and thoroughly cleaned them and put them back on the bike. The bike ran for the first time since I got the bike and would stay running until I shut off the bike. Then it wouldn't start again. That is when I noticed my spark isn't blue of which is optimal running spark.
I did however begin to think to play with the mixtures since I only turned the mixture screw out 2.5 times and that may be an issue. I am going to try that now.
Richard
post #4 of 11 (permalink) Old 05-03-2015, 12:16 AM
Maybe check the voltage at positive side of the coil while cranking. Should also be an ohms test for the coils in the manual.
post #5 of 11 (permalink) Old 05-03-2015, 04:29 AM
Are you using a new battery ?
post #6 of 11 (permalink) Old 05-03-2015, 08:12 AM
rsavant's Avatar
You say it sat for a while. Was it protected from the weather? Have you checked compression? Could the cylinders have rusted while it was sitting?
"Katie"
Mustang seat
About 25k miles
Pick up coil mod
Petcock rebuilt
rsavant is offline
post #7 of 11 (permalink) Old 05-03-2015, 09:28 AM Thread Starter
no the compression is good. The bike was inside when it sat up. There is no rust on the bike except for the instrument cluster housings, the rest of the bike is clean.
I am thinking it possibly could be in the mixture ratio or the coils/wires are weak and or a combination of both giving me this issue. I ran the bike in the buikding for about 5 minutes twice lastnight and as long as it ran, it ran perfectly so it makes me think the mixture is correct. The bike would idle very low and not shut off. Just when I shut it off, it won't start back.
Richard
post #8 of 11 (permalink) Old 05-03-2015, 10:45 AM
I am thinking it possibly could be in the mixture ratio or the coils/wires are weak and or a combination of both giving me this issue. I ran the bike in the building for about 5 minutes twice last night and as long as it ran, it ran perfectly so it makes me think the mixture is correct. The bike would idle very low and not shut off. Just when I shut it off, it won't start back.
Sounds like a Hot Start issue..... Perform the "Pick-Up Coil Mod"
Also, suggest you replace the Spark Plugs and Spark Plug wires
WilliamTech
post #9 of 11 (permalink) Old 05-03-2015, 11:29 AM
master of reality
Yes pick up coil mod solved the hot start issue for me
It is what it is.
michiganrider1982 is offline
post #10 of 11 (permalink) Old 05-03-2015, 04:27 PM Thread Starter
I did the coil mod 2 years ago. Spark plug wires and spark plug is next. Where do I get the wires and what kind of spark plugs do you recommend?
Richard
