Turn Signal Relay Info? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 05-25-2008, 01:36 AM Thread Starter
Hi folks - I'm a complete newbie to the VN750 forums and I have a question
for you: On a 1986 Vulcan 750 can anyone tell me what the correct
part number is for the turn signal relay?
I'm looking for the numbers on the relay itself, not Kawasaki's part number
or a number from a retailer such as Ron Ayers.
I'm working on a friend's bike; I believe the relay is bad and I want to
verify that the correct relay is in the bike.
Thanks in advance for any help provided!
Rob
IrocRob is offline
post #2 of 6 (permalink) Old 05-25-2008, 10:39 PM
Sky Rider's Avatar
The correct part numner IS the Kawasaki part number. There really isn't any other way to get the part. Try ohming it out to see if the relay coil hasn't failed. The only other thing would be to apply the 12 volts from an outside source and see if it works then. If not, replace.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #3 of 6 (permalink) Old 05-26-2008, 10:13 AM Thread Starter
The relay that's in the bike now is made by Nippondenso and reads as follows:
FA249ED 12.8v 85c/m
066500-0213 TURN SIGNAL
21(23)W x 2 + 3.4W
HAZARD WARNING
21(23)W MAX. 4 BULBS
(A) 79002 DOT
Can anyone out there verify this is the correct part?
The circuit on the bike checks out fine from the relay out to the lights.
I know this because applying 12v to that circuit allows the turn signals,
(and hazards) to operate correctly with the switch. So I know the circuit
is fine from the relay out to the lights. I don't know if the circuit is good
going into the relay, or if the relay itself is bad, or just not correct for the
bike. I suppose these are cheap enough to just go buy a replacement, but
this is not my bike and I'd like to be certain before spending someone elses money....
Thanks Again!
Rob
IrocRob is offline
post #4 of 6 (permalink) Old 05-26-2008, 10:22 AM
Hello there if i were you i would go spend a few bucks maybe 9.00 or so for a eltirconic flasher.... at any auto store and replace it with the old one....fixed my problems when my blinkers wernt working right...i was gonnado what your doing then i went this route and BANG it worked..give it a shout you wont lose as much money and might just work
Vulcan-4-life is offline
post #5 of 6 (permalink) Old 05-26-2008, 05:07 PM
Most of the relays have standard contact numbers. If all else works check for battery and ground inputs. when I hard wired my timer flasher in I lost the idiot lights after the switch was released. That gives me the idea that you should be looking for 12v from the turn signal switch. Correct assumption forum?
Rckmtn
Dennis Huff
Cheyenne, Wy.
05 VN 750
Spitfire windshield
self canx turnsignals
Jardine 2 into 2
Luggage rack
Extended passenger backrest
KURYAKYN LED voltmeter
130 DB horns
rckmtn is offline
post #6 of 6 (permalink) Old 05-28-2008, 09:40 PM
Also check you bulbs! sometimes if there is a odd ball bulb in there even though it lights up it still can cause the system to not act right!
buffalo bill is offline
