bear with me a bit here - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 04-19-2015, 12:00 AM Thread Starter
90 vn750. Ear shave, ignition coil/relay upgrades have been done.
I went around the block the other day then parked it, since then it will not start.
Hit the start button and can hear the relay in the fuse box click, used a test light to the start solenoid and get it to light up, jump the solenoid and get it to crank but will not fire. HELP!?
Worst part is that I'm selling it and had two people come over with cash in hand but since it wouldn't start they both walked away.
cowboy_mike is offline
post #2 of 9 (permalink) Old 04-19-2015, 12:35 AM
I am no electrical guru, but these thoughts come to mind:
Are you sure the emergency kill switch is in the on/run position?
If it is, flick it back and forth 2 or 3 times between ON and OFF to clear any corrosion off the contact points, then try to start it again.
Are you saying the ear shave and ignition coil/relay mods were just done recently and the bike was ridden around block, but since then the plugs will not fire?
Or the mods were done some time ago, the bike started and ran well for a time, then sat for some time before being started and drove around the block the other day? But will not fire now when cranked over?
post #3 of 9 (permalink) Old 04-19-2015, 12:47 AM Thread Starter
Mods were done last year and ran great for a few thousand miles. I parked it in January and rode it the other day then this issue came up. Yes the kill switch is in the correct position and I tried toggeling it several times to see if there was corrosion.
post #4 of 9 (permalink) Old 04-19-2015, 08:51 AM
JM2001's Avatar
First things first. What is your battery voltage? You need about 12.6-12.8. Check both grounds, battery to ground and battery box to engine ground.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #5 of 9 (permalink) Old 04-19-2015, 12:32 PM
I'd check battery voltage. Clicking when starting can occur when voltage is too low to crank the bike.
post #6 of 9 (permalink) Old 04-19-2015, 10:07 PM
Memphis's Avatar
I agree with thtanner, this is exactly what mine does when the voltage is too low. Check it with the key turned on would be my only tip. When my battery was too low to start it, it was not too low until I turned the key to on. So when I tested the battery it should have been ok but wasn't when the key was on.
Memphis is offline
post #7 of 9 (permalink) Old 04-20-2015, 07:10 PM Thread Starter
Its not the battery, it has been fully charged and even had it on boost and got no click as if the battery was dead, the click was a single click from the start relay.
post #8 of 9 (permalink) Old 04-20-2015, 10:02 PM
JM2001's Avatar
You have a bad battery or a bad starter solenoid. You still haven't told us what your battery voltage is. You can charge it all night and still not have enough volts. You can also put it on a booster and not be able to start the bike. You could have a bad cell and show 12-12.3 volts. Not enough to fire the bike. If the battery is good, then check the starter solenoid.
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #9 of 9 (permalink) Old 04-21-2015, 01:19 PM
Jiggle the key. Ignition switch will do this too out of the blue.
