melted battery terminal - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 05-21-2008, 06:53 PM Thread Starter
I had trouble starting my bike the other day, to the point the battery gave out.
I pulled the seat off today intending to jumpstart it. To my surprise, the negative terminal had completely melted. There's a problem !
I have a picture up on Flickr, but I can't post the URL here yet. Go to Flickr and search for "VN750 melted battery terminal".
I bought this Yuasa battery about 18 months ago and only driven about 2000mi since then.
I know I am in for a new battery, but I don't want this to happen again.
Any ideas ?
qazwsx is offline
post #2 of 4 (permalink) Old 05-21-2008, 07:13 PM
rare but not unheard of. cause is usually poor, loose connection on the battery posts. the repeated attempts at cranking plus whatever before generated enough heat, to melt the post.
aradams is offline
post #3 of 4 (permalink) Old 05-22-2008, 12:04 AM
Sky Rider's Avatar
Make sure you replace the batt with a maint free battery. I'd also recommend going through all the electrical connections and making sure everything is nice and tightly connected before putting the new batt in. Something in your wiring caused the ground lead to heat up which could happen again if you just drop in the new batt without checking the wiring. Be a bummer to toast a brand new batt.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #4 of 4 (permalink) Old 05-22-2008, 12:06 PM
Wow, that's pretty rough, are you sure it wasn't just broken off instead of being melted?
Harvey_birdman is offline
