Got the new Stator today Woohoo! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 05-21-2008, 12:28 AM Thread Starter
Sky Rider's Avatar
Started tearing Ursula down for the dreaded stator install today. Hopefully, I'll have her back together in a week or so. New R/R is coming along with the assorted gaskets and new inserts for the left side balancer.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #2 of 3 (permalink) Old 05-21-2008, 09:47 AM
93VN750's Avatar
Who's stator did you get?
Though not part of the manual's procedure, I found it much easier to remove the rear wheel and unload the tension on the front bevel gear case. Also makes re-assembly easier as I found putting the bevel case back on with the shaft spring loaded was nearly impossible. Others have done this, I could not.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #3 of 3 (permalink) Old 05-21-2008, 12:16 PM Thread Starter
Sky Rider's Avatar
I went with the Electrosport.
I didn't have any problems reinstalling the front bevel geat with the drive line in place when I rebuilt her about 2 years ago but if I do, I'll use your suggestion.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
21480 Miles
VROC #8542
