led lights - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 19 (permalink) Old 04-12-2015, 09:21 PM Thread Starter
prfredo's Avatar
led lights
I purchased a set of cheap LED lights online for underlights(putting them under the tank shining on to the motor)... Just to try it out!.. i figured ill connect them straight to the battery like i would a battery tender but with an on off switch.. But i believe i read somewhere that this could cause some trouble with my electric system.. Anybody know if this is true? If it is any pointers on this matter?
prfredo is offline
post #2 of 19 (permalink) Old 04-12-2015, 11:08 PM
Sean Karp's Avatar
Why not use your accessory leads instead?
"For practice is better than art. Your exercise does well without the art, but the art is not much good without the exercise." -Hanko Dobringer, 1389
Sean Karp is offline
post #3 of 19 (permalink) Old 04-13-2015, 01:01 AM
Ndr
The only problem I can see this causing is the potential to forget to turn the switch off and draining your battery (albeit slowly due to it being LEDs)
The Accessory wires are always on, even with the ignition off. SO, this would be no different then hooking directly to the battery with a switch.
I would recommend hooking a relay that activates off of a switch power wire (such as the running lights or tail lights) and running the power through the relay from either the battery or accessory wires.
Ndr is offline
post #4 of 19 (permalink) Old 04-13-2015, 05:23 AM
There is an aux lead under the right side cover. That's where I would connect it.
post #5 of 19 (permalink) Old 04-13-2015, 02:42 PM
I mounted LED's as accent lights as well.
I used the accessory leads under the left cover and simply added a (fused) switch on the top of the cover to turn them on and off with a push on - push off switch.
post #6 of 19 (permalink) Old 04-13-2015, 05:05 PM Thread Starter
prfredo's Avatar
Thanks guys. I will look for the leads and go from there..
prfredo is offline
post #7 of 19 (permalink) Old 04-13-2015, 05:15 PM
The accessory leads are fused. (10 amp in the junction box) I'd use them for this reason even if I'm adding a switch. So not the same as wiring direct to the battery.
post #8 of 19 (permalink) Old 04-13-2015, 05:58 PM Thread Starter
prfredo's Avatar
Thanks.. I didn't know there was leads.. thats probably how I'll hook them up..
prfredo is offline
post #9 of 19 (permalink) Old 04-14-2015, 12:21 AM
Sean Karp's Avatar
Anyone use the ones under the headlight? If so what for?
post #10 of 19 (permalink) Old 04-14-2015, 12:31 AM
'03 VN750 "Rosie"
bstew7890's Avatar
I have mine wired exactly that way. It was already set up when I bought it, with a switch on the right side cowl and lights under the frame, but I've moved the lights to under the tank. No problems but it's a pain when disconnecting the battery, and I like that it makes the bike more visible from the side.
'03 VN750 "Rosie"
Purchased in June 15, 2010
Lubed Splines
Lubed and Adjusted Clutch Cable, Throttle Cables.
Relocated Voltage Regulator
Brakes Bled
Luggage Rack
Lazy Rider Bag
Leather Saddle Bags
Legitimate Title!! (finally!) Aug 30, 2010
New AGM Interstate Battery Sept 15, 2012
2008 Hyosung GV250 (sold!)
bstew7890 is offline
