Brake Light - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 05-19-2008, 01:15 PM Thread Starter
Brake Light
I noticed when I arrived at work this morning that my brake light isn't working off of the front brake. Rear brake lights it right up, but not the front. Any quick ideas before I get home today and start tracing wires? P.S. turn signals and park lights are working fine......
Respects
Cassack is offline
post #2 of 5 (permalink) Old 05-19-2008, 02:28 PM
First thing I'd look at are the wires at the lever switch. Might just be loose, or the switch could be bad or need cleaned.
I wouldn't think it'd be that the switch is stuck, as the light would stay on then.
post #3 of 5 (permalink) Old 05-19-2008, 02:39 PM
oglejust's Avatar
make sure the 2 wires r still connected... theyre easy to disconnect so that may be ur problem
.... slightly modified
oglejust is offline
post #4 of 5 (permalink) Old 05-19-2008, 04:04 PM
As stated ... check the wires to make sure they're tight. You can also pull them and touch them together ... if they light it's the switch.
KLank is offline
post #5 of 5 (permalink) Old 05-19-2008, 10:57 PM Thread Starter
gunk on the switch wire. Cleaned, connected and all better now. Thanks.
Cassack is offline
