Neutral light/Clutch switch - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 05-15-2008, 08:23 PM Thread Starter
liljd's Avatar
Does anyone know what would cause the neutral light to no longer work and make you have to squeeze the clutch in to start it? Mine was fine till a few days ago right after I marbled it. I went to start it a day later and the light quit and now can't start it without squeezing the clutch in.
James
1985 vn700 (T'Plana)
Gremlin bell
HD-O shield
saddlebagged
custom made supports
tool bag
extended backrest
Protac backrest
Highway pegs
custom mirrors
custom grips
V&H cruisers
lever covers
DieHard AGM
Kuryakin battery gauge
and LED taillights
marbled
____________________
VROC #27169
Tn VROC #134
www.youtube.com/thetrueliljd
liljd is offline
post #2 of 7 (permalink) Old 05-16-2008, 03:11 AM
Hi James
The bike thinks that it is in gear and needs the clutch pulled in to start, this is one of the bikes protection features, built into the diodes in the junction box.
I would guess that either the neutral switch is not operating or a wiring issue has occured (broken wire, disconnected at a connection point, etc ), best check out the neutral switch circuit with a multimeter or test lamp.
The other possible cause would be something has happened to the diode in the junction box for the neutral switch.
Happy hunting
DaveT
Kuala Lumpur
davet is offline
post #3 of 7 (permalink) Old 05-16-2008, 03:14 AM
ipfreely's Avatar
There is a wire that runs down the back of the motor to a switch on the very bottom or back of the motor. I forget and I am at work. Possibly a green wire. If you pulled it apart it will act like that. More than likely that is your problem. If you cant find it, pm me and I will look when I get home to tell you where it stops and starts, and the color. Good luck
Kuryakyn Flame Grips
Bar End helmet locks
Chrome / Gold "Live to Ride Mirrors"
Coastered, Shaved & Jetted
K&N Pod Air Filters
KisanTech headlamp & Taillight modulators
Iridium's
Leather Lyke Hard Bags
Voltmeter, Clock
Stebel Nautilus horn
Slipstreamer SS28
J&M CB Radio
Audiovox CCS-100 Electronic Cruise Control
Mustang Seat, Protac Drivers Backrest
And of course the obligatory stator replacement[/FONT]
ipfreely is offline
post #4 of 7 (permalink) Old 05-16-2008, 10:54 AM
85 VN 700
curtis97322's Avatar
There's 2 switches that may be the culprit - one goes up to the clutch lever, one goes to the sidestand switch.
I'd be almost certain that it's the wire that goes to the clutch lever (3 wires). With 2 of the wires jumped to eachother the bike will start, but only in neutral. With 3 of the wires jumped to eachother the bike will start in any gear, but the green light will stay on constantly. With 2 jumped the bike will start in any gear and no annoying green light unless in neutral.
Seems like with the other combo of 2 wires the bike just won't start...
Hope that helps? Temporarily bypassing the switch (even shorting the 3 to eachother since you'll be checking the switch) would help see if the clutch lever is suspect...
Myself - I've bypassed both the sidestand and the clutch lever switch... but not all should do so...
Curtis - Albany Oregon.
Ammo Can Saddlebags
Hit the 24k mile July 2008
curtis97322 is offline
post #5 of 7 (permalink) Old 05-16-2008, 11:41 AM
The clutch switch on my bike is bad. I have to start it in neutral. But, my neutral light still works.
I'd guess you may have knocked a wire loose somewhere.
post #6 of 7 (permalink) Old 05-16-2008, 03:57 PM Thread Starter
liljd's Avatar
Thanks guys, I have had more trouble with the wires and juction box. I've only had this since the end of jan. and both the headlight and fan relays are shot, and I have found burnt wires. Now this happened and I'll look for what ya'll said to.
Oh...PM sent
James
Gremlin bell
HD-O shield
saddlebagged
tool bag
extended backrest
Protac backrest
Highway pegs
custom mirrors
custom grips
V&H cruisers
lever covers
DieHard AGM
and LED taillights
marbled
VROC #27169
Tn VROC #134
liljd is offline
post #7 of 7 (permalink) Old 05-17-2008, 04:26 PM Thread Starter
liljd's Avatar
I found the green wire and it's broken at the switch on the bottom of the engine. Thanks ya'll!!!
James
Gremlin bell
HD-O shield
saddlebagged
tool bag
extended backrest
Protac backrest
Highway pegs
custom mirrors
custom grips
V&H cruisers
lever covers
DieHard AGM
and LED taillights
marbled
VROC #27169
Tn VROC #134
liljd is offline
