tail light problems - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 05-14-2008, 11:25 AM Thread Starter
pro skateboarder
yoshiaka13's Avatar
tail light problems
ok here's my problem. the person I bpught my vn 750 from bought it from a guy that installed an aftermarket tail light. iron cross west coast choppers tail light. I mean I like it because it best reflects my rebelous attitude. none the less my riding light doesn't work as of yesterday. hpwever the brake light works when I use the brakes. real bright too when I use it. but if I rev it a little while the brake light is on it flickers a little. any ideas.. I know there are some of you out there that are practice the religion of OEM. you can keep your OEM comments. as I like aftermarket stuff to help accent your personality. why look like everyone else when we are all not the same. thanks
yoshiaka13 is offline
post #2 of 5 (permalink) Old 05-14-2008, 11:30 AM
Elemental's Avatar
Flicker at a steady rate? Increasing with engine speed?
1990 Vulcan
Saturn Plum/55 Tbird red.
Accel Coils.Mangacore wires.Corbin Seat.
Cobra exhaust.Jetted to 1.1 lamda.
Wide levers,cushy grips, All steel lines....
Actually, I've changed more stuff then I can remember.
Elemental is offline
post #3 of 5 (permalink) Old 05-14-2008, 11:54 AM
Did you check the bulb to see if it's burnt out? Are the front running lights working?
And is the brightness of the brake light you mention seem brighter than before?
First thing I'd check would be the bulb and the connections.
post #4 of 5 (permalink) Old 05-14-2008, 12:18 PM Thread Starter
pro skateboarder
yoshiaka13's Avatar
the flicker is not steady. it only does it when it starts reving up. the tail light is as bright as it should be while brakes are applied. this particular tail light has only one bulb instead of two and a seperate one for the license plate as I noticed from the wiring diagram. on the bottom of the cross is a clear piece of plastic so the running light also illuminates the plate. ingeneous if you ask me. instaed of 3 bulbs running the tail light and the plate light you have one which from an electrical point of view would cut down on voltage usage. all the other lights work just fine with no problems or dimmness.
post #5 of 5 (permalink) Old 05-14-2008, 02:59 PM
85 VN 700
curtis97322's Avatar
Sounds like ya have a short...
Pull the seat and trace the wiring, I'd imagine there's a poorly done connection.
And I don't think anyone here practices the religion of OEM - check the sigs, most of us have SOME mods... about the only thing I see recommended to stay OEM is exhaust...
Curtis - Albany Oregon.
Ammo Can Saddlebags
Hit the 24k mile July 2008
curtis97322 is offline
