Headlight Modulation - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 17 (permalink) Old 05-12-2008, 04:29 PM Thread Starter
darrelc5's Avatar
I have a headlight modulator on my low beam headlamp and I recently started to question whether it's working as expected. Plug the module between the harness and the headlamp it winks the bulb on and off, right? Here's the rub; the headlight warning indicator flashes as the bulb is turned on an off and this means that the reserve lighting controller senses that the low beam lamp is burned out and SHOULD be trying to switch on the high beam lamp on each cycle. From looking at the headlight, I cannot tell if it's modulating between low and off four times per second, or low and high. I haven't yet tested for voltage on the high beam circuit to see if the controller is switching it on. Has anyone else looked in to this?
Darrel
'03 Vulcan 750 (90k miles)
-Corbin Seat
-V-Force Windshield
-LeatherLyke Touring Bags
-Chrome Luggage Rack
-Headlight Modulator
-Brakelight Flasher
-MF Battery
-Heads-Up Voltage Monitor
-Replaced Stator (9,000 and 16,000 mi.)
-Oil-cooled Stator Mod (photos)
-Replaced and Relocated R/R
-Greased rear splines
-Fused Stator (photos)
-Metzeler ME880 Marathon 170/80-15 (Rear), 110/90-19 (Front)
-TOC MCCTs installed
-Headlight Relays
SOLD - 2013
darrelc5 is offline
post #2 of 17 (permalink) Old 05-12-2008, 05:45 PM
Calif Rider
weh44att's Avatar
My modulator is hooked up to the High beam, at least this is what the instructions say. Yes the headlight warning light flashes on and off as the modulator flashes the high beam. Calif says you have to have it on the high beam.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #3 of 17 (permalink) Old 05-12-2008, 05:59 PM
Drive less, ride more...
theauhawk's Avatar
Ditto--have mine hooked up to the high beam (only), also.
And yes, the headlight indicator idiot light flashes on and off with the modulator.
Why would you want your modulator hooked up to the low beam, anyway?....
'05 VN750
theauhawk is offline
post #4 of 17 (permalink) Old 05-12-2008, 06:04 PM
Does it have a light sensor on it, so it wont flash at night?
If so, maybe where you have it is too dark and it thinks it's nighttime?
post #5 of 17 (permalink) Old 05-12-2008, 07:18 PM
Should have a photo cell. I thought it is illegal to run on high beams, very offensive for oncoming traffic especially in daytime.
Mastertech is offline
post #6 of 17 (permalink) Old 05-12-2008, 08:02 PM
liljd's Avatar
What is this critter we speak of????? Sorry but I really don't know lol!
James
1985 vn700 (T'Plana)
Gremlin bell
HD-O shield
saddlebagged
custom made supports
tool bag
extended backrest
Protac backrest
Highway pegs
custom mirrors
custom grips
V&H cruisers
lever covers
DieHard AGM
Kuryakin battery gauge
and LED taillights
marbled
____________________
VROC #27169
Tn VROC #134
www.youtube.com/thetrueliljd
liljd is offline
post #7 of 17 (permalink) Old 05-12-2008, 09:05 PM Thread Starter
darrelc5's Avatar
Exactly! I don't want to piss anyone off, just be noticed.
My unit has a photocell so the flashing is disabled at night. However, if the reserve lighting device thinks the low beam is burnt out every time the modulator winks it off, won't it try to energize the high beam? I think my headlight might therefore be blinking between low and high rather than low and off.
Has anyone with a headlight modulator on the low beam noticed this?
Darrel
-Corbin Seat
-V-Force Windshield
-Brakelight Flasher
-MF Battery
-Headlight Relays
SOLD - 2013
darrelc5 is offline
post #8 of 17 (permalink) Old 05-12-2008, 09:16 PM
I think you are right darrel
post #9 of 17 (permalink) Old 05-12-2008, 09:21 PM
HAWK
Ccspinner's Avatar
The directions state to put it on the high beem so you can turn it off when you switch to low beam.
And mind does flash my headlight warning light also.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #10 of 17 (permalink) Old 05-12-2008, 09:24 PM
Ill bet it flashes high/low beam then, that how it gets that flutter, its just an electronic high/low beam switch.
