bike died on the street, battery dead - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 22 (permalink) Old 05-12-2008, 01:31 PM Thread Starter
bike died on the street, battery dead -- Updated
So I'm going to go ahead and assume its a charging issue...brand new MF battery and brand new plugs...i haven't looked at anything yet but if it is a charging issue is there a definitive method for telling whether its the stator or the r/r? could it be both?
whats the best prices you have found for the part(s)?
thanks
wowitsmike is offline
post #2 of 22 (permalink) Old 05-12-2008, 01:38 PM
On His Lady Vulcan
wkrizan's Avatar
thanks
http://www.4strokes.com/tech/fault_find.pdf
Pictures of the "Ladies"
wkrizan is offline
post #3 of 22 (permalink) Old 05-12-2008, 01:43 PM
On His Lady Vulcan
wkrizan's Avatar
http://www.bikebandit.com/aftermarke...264793+1266341
wkrizan is offline
post #4 of 22 (permalink) Old 05-12-2008, 02:28 PM Thread Starter
went and pulled the battery...
rectifier looks like it could possibly be original, hehe...i'll run that test tonight and see what i can find...hoping its the r/r cause that's easy...anyone want to crush my dreams now before i get too hopeful?
also, i noticed in the fuse box that the 30 amp main fuse was loose...could this be the problem? can't check until i get battery charged thogh
post #5 of 22 (permalink) Old 05-12-2008, 02:49 PM
It could be the fuse...check all the wires for damage...I was having the same problems, and I found that after three days of trouble shooting if i would have started by doing continuity checks of all the wires I would have found the problem faster. How does the connector look...if it is melted or burnt looking then check all the wires for a short to ground.
post #6 of 22 (permalink) Old 05-12-2008, 02:58 PM Thread Starter
the wires that i did check, those around the battery and rectifier all looked good...and it wasn't the fuse...the battery is dead...
i've got a motorcycle mechanic friend and im taking the bike to his house tonight and he's going to check all that stuff for me...i'll keep you guys updated...if you've got any helpful hints, i'm all ears
and slim, you and i aren't very far from each other...im in san antonio
post #7 of 22 (permalink) Old 05-12-2008, 03:04 PM
Slim would know!
Mastertech is offline
post #8 of 22 (permalink) Old 05-12-2008, 03:05 PM
Bring it by tonight, i'm in Nebraska!
post #9 of 22 (permalink) Old 05-12-2008, 09:42 PM
Crobins365's Avatar
I've got a spare working rectifier if you need one. Hope that's all it turns out to be!
C
Crobins365 is offline
post #10 of 22 (permalink) Old 05-12-2008, 10:21 PM Thread Starter
Cindy, that would be awesome! how can i get in touch with you?
We took a closer look this evening and ruled out the junction box and fuses...we noticed a somewhat large amount of acid corrosion...the connector on the r/r was very corroded as was the r/r itself...and then two of the yellow wires leading from the stator had some heat damage and/or were corroded...one was even exposed but i don't think it was going to ground...my mechanic friend is going to look at it more in-depth this evening and let me know...he's of the mind that we repair the wires from the stator and replace the r/r and my problems should be fixed...
again, any and all insight is much appreciated...
