How man times can you charge a MF battery? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 05-11-2008, 08:51 PM Thread Starter
I really like the bike, but am having problems starting it. My battery has died at least 6 times in the past year. Each time, I take it out and recharge it and it works just fine (until is runs out juice, which is becoming more frequent). I ride almost every day.
Right now, I have a Yuasa MF that I installed last summer. Most of my rides are short and I ride all winter in NYC. I'm pretty sure everything else it OK. I rode 500 miles this past week almost all on the freeway and it was fine. And, I had tune up a couple of weeks ago and made sure they tested the charging system. I think I'm going to replace my battery and charge it every few weeks to keep it strong. Does that sound like a good way of dealing with my situation?
Thanks,
John
JohnMack76 is offline
post #2 of 4 (permalink) Old 05-11-2008, 08:59 PM
No!
You should not have to charge it every few weeks, if you are riding it on a monthly basis.
You may have a weak battery, have it tested;
Your charging system may be guilty, run a volt meter on it,
should be 13-14.7volts engine running.
May have a drain on the system, run an amp meter in line by taking the ground cable off at the battery and in series attach a voltmeter set up at 10 amps, this bike should have zero drain when key is off.
Mastertech is offline
post #3 of 4 (permalink) Old 05-11-2008, 09:19 PM Thread Starter
Do you think it might be related to my rides not being sufficient to properly charge the battery?
I ride about 5 times a week, but my rides are usually short and I have been riding all winter when the temperature is above 30. The battery was fine for about 6 months and than it died. I charged it and was OK for another 2 months until it died again. And technically, it didn't really die. The headlight was on, but there wasn't enough juice to start the bike. After the 2nd time I couldn't start it, it seemed to drain faster. Do you think I've tried to charge it to many times?
post #4 of 4 (permalink) Old 05-11-2008, 09:22 PM
That can happen john, everytime it runs completly down it weakens it.
Put a volt meter on the battery terminals with the engine running, and tell me what readings you get!
