Not charging, quick ? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 05-11-2008, 05:56 PM Thread Starter
So if my battery isn't charging, and I'm getting a steady 12 volt read off of it whether bike is running or not, idle or revved, is their any reason I SHOULD think it's the stator and that replacing the R/R is a shot in the dark? I'm reading other people having strange charging issues and being suggested possible stator problems, but they are getting SOMETHING more than a steady 12 volts off their bikes.
Thanks for any help!
mad_max is offline
post #2 of 9 (permalink) Old 05-11-2008, 06:15 PM
Yes, you should be getting more than 12 volts. Unless you voltmeter is whack, you have a problem.
There is somewhere here? detailed info on how to check the stator. Hopefully someone will point you to it...and there should be a way to check the R/R.
Before doing this..recheck ALL of the stator wire, R/R and battery connnections. Sometimes a loose ground can give you a bad reading.
You should also remove the battery, put it on a charger and check it when charged.
post #3 of 9 (permalink) Old 05-11-2008, 06:26 PM
You should be at least 13 volts charging minimum, 14.7 maximum
Go to voltage regulator first for diagnosis, dianne has a good test procedure here on the forum i beleive;
Charge the battery first on low amps and test battery with a load tester,
If you dont have one, a fully charged, healthy battery will read 12.5 volts, if it reads 12 volts, it is not fully charged or will not hold.
There is a chart for testing the voltage regulator in the clymers manual, we should all own one of them. Let us know.
Mastertech is offline
post #4 of 9 (permalink) Old 05-11-2008, 06:29 PM
On His Lady Vulcan
wkrizan's Avatar
Use this PDF file it should do the trick for you http://www.4strokes.com/tech/fault_find.pdf
Peace
Pictures of the "Ladies"
wkrizan is offline
post #5 of 9 (permalink) Old 05-12-2008, 03:26 AM Thread Starter
Thumbs up A lesson for me...
So I print our the PDF files (thanks, wkrizan) and I grab my Clymer manual and my multi tester (even though I am a multi-idiot) and get down on my back and follow the yellow wires to where one of them is disconnected. I plug it back in and now I am getting a charge.
My lesson learned is to look for the easy things before you delve into the complicated.
Thanks for all the quick responses, folks. Hopefully I'm fixed!
mad_max is offline
post #6 of 9 (permalink) Old 05-12-2008, 11:02 AM
Your fixed!!!!!!
post #7 of 9 (permalink) Old 05-12-2008, 12:07 PM
90% of the time it is the simple things. Always do a visual inspection and and try reseating the plugs. After that start your T/S tree. When I worked electronics the simple things like power cords and internal fuses wasted a lot of inexperienced techs time. They almost always went to the hardest things to T/S fix not thinking of KISS(keep it simple stupid).
Rckmtn
Dennis Huff
Cheyenne, Wy.
05 VN 750
Spitfire windshield
self canx turnsignals
Jardine 2 into 2
Luggage rack
Extended passenger backrest
KURYAKYN LED voltmeter
130 DB horns
rckmtn is offline
post #8 of 9 (permalink) Old 05-12-2008, 12:35 PM
On His Lady Vulcan
wkrizan's Avatar
Hey I live by that remark...lol
wkrizan is offline
post #9 of 9 (permalink) Old 05-12-2008, 03:34 PM Thread Starter
K.I.S.S. is my new mantra
I'm going to tattoo it backwards on my forehead to remind me everymorning...
This forum is the greatest!
mad_max is offline
