You Gotta Get One Of These - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 03-25-2015, 02:19 PM Thread Starter
Mod
Birdhunter02's Avatar
Just purchased this blinking led for rear brake lite.
https://www.superbrightleds.com/more...sher/923/2274/
My brother has the modulator and always liked it. Saw this and it's plug and play. Nothing else to add. No wiring. Works great and is very bright.
2003 1600 Classic
Sold
900 Seat Mod
Iradiun Plugs
V and H Cruzers
Windshield with Lowers
LED Tail Lights
Saddle bags
Chads Floor boards
Highway pegs
Birdhunter02 is offline
post #2 of 13 (permalink) Old 03-25-2015, 04:39 PM
JM2001's Avatar
Two questions. Did you replace both tail light bulbs? You say they are bright, the regular bulb is 5/21 watts. The 3 watt led is that bright? Thanks
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #3 of 13 (permalink) Old 03-25-2015, 10:41 PM
Ordered some really cheap ones for the tail and license plate, hoping they aren't made from graham crackers. They are somewhere on a slow boat from China right now. Not flashers though, just plain LED bulbs.
Tried to compare specs but the spec categories are almost all different.
post #4 of 13 (permalink) Old 03-25-2015, 10:44 PM
Lol Spockster. Made from graham crackers.
post #5 of 13 (permalink) Old 03-25-2015, 11:41 PM Thread Starter
Mod
I have a 1600 and it only has one bulb. Don't let the 3 watts fool you. It's bright.
2003 1600 Classic
Sold
900 Seat Mod
Iradiun Plugs
V and H Cruzers
LED Tail Lights
Saddle bags
Chads Floor boards
Highway pegs
post #6 of 13 (permalink) Old 03-26-2015, 01:12 AM
JM2001's Avatar
Thanks. I have Jam Strait LED bulbs for my turn signals, brake/ tail light, and license plate light. They work well. I like your Flasher idea so I'm going to try these. Much cheaper.
http://chromeglow.com/products/bulbs...om-jam-strait/
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #7 of 13 (permalink) Old 03-26-2015, 01:49 AM
Ndr
I have one of these in my 900 currently. When I was running the 750, I had two of them. (one probably would have been plenty along side a standard bulb)
they are BRIGHT. I'd hazard a guess to say that hey are about 3 times as bright as the stock 5/21 watt bulb.
The one in my 900 was pulled from the 750, so I've been running that same bulb for a few years now.
Was worth every penny in my opinion.
Ndr is offline
post #8 of 13 (permalink) Old 03-27-2015, 09:26 AM
rsavant's Avatar
Doesn't the listed wattage refer to power consumption rather than light output? If you look at LED replacements for incandescent the package will describe light output compared to the energy consumption of an equivalent incandescent. So yes, the LEDs do have much higher output while drawing less current.
Soon after I got my bike I purchased a red strobe from this same company. As I've posted before, when they say "super bright" they mean it. The strobe I have can be set to 20 different patterns. I mounted it on the trunk and feel much safer when I'm stopped in traffic. Until the car coming from behind is safely stopped, I keep the brake applied to make sure I'm seen. The strobe is incredibly bright, and only about $30. The trunk is the perfect mounting location for it and I highly recommend it.
"Katie"
2002 VN 750, stock except for accessories
Mustang seat
Super Bright LED brake strobe on trunk
About 25k miles
All drive train maintenance performed, drive shaft coupler replaced
Way more experienced at pulling VN 750 carbs than I ever wanted to be.
TOC ACCT rebuild kits installed
Pick up coil mod
Cooling system flushed, refilled with fresh coolant
Petcock rebuilt
VN sold, current steed Honda ST 1300
rsavant is offline
post #9 of 13 (permalink) Old 03-28-2015, 11:18 AM
Chasin' the blacktop
Spencer1's Avatar
So do you also need the resistor?
North Georgia
Spencer1 is offline
post #10 of 13 (permalink) Old 03-28-2015, 12:11 PM
Question: Does the light always blink/strobe? Or is it one of those that blinks for a short time then goes steady?
Old Bike: 2006 VN750 - Sold
eusjma is offline
