weird... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 03-17-2015, 11:27 AM Thread Starter
1999 Vulcan 750
LoneVulcan750's Avatar
weird...
Strange thing happened to me, went to take out the bike the other day and didn't get a 1/2 mile, she started spitting and sputtering then died. Got her started again got home turned her off. Filled up with gas This is where it was weird turned key and had NO power to anything, battery was full charge, all connections were tight. Went out yesterday and turned the key and I Have power & she started right up
1999 Kawasaki VN750
DeGoated
Highway bar
Saddle Bags
Emblems Off
iridium plugs
Ultra HID Light
Better mirrors
Modded seat
Throttle Assist
Custom sissybar
http://www.kuryakyn.com/Products/378...hrottle-Assist
Wishlist
Never ending
LoneVulcan750 is offline
post #2 of 6 (permalink) Old 03-17-2015, 11:39 AM
start with the basics on this.
verify all connections at battery are good.
verify all grounds are good
check the contacts in ignition switch (sounds like this is most likely)
next time it acts up electrically, try wiggling the switch or turning it just past the run position to see if anything changes
michiganteddybear is offline
post #3 of 6 (permalink) Old 03-17-2015, 11:49 AM
Yep sounds like a loose ground wire, or maybe a dirty/faulty ignition switch ..
post #4 of 6 (permalink) Old 03-17-2015, 12:55 PM Thread Starter
1999 Vulcan 750
Thanks for the quick responses I will check all the wiring today
1999 Kawasaki VN750
DeGoated
Highway bar
Saddle Bags
Emblems Off
iridium plugs
Ultra HID Light
Better mirrors
Modded seat
Throttle Assist
Custom sissybar
Wishlist
Never ending
post #5 of 6 (permalink) Old 03-17-2015, 10:20 PM
KAT
KAT's Avatar
When I first got my bike I had some similar gremlins, there are step by step instructions along with some really good pictures on cleaning the ignition switch, make sure to check the bullet connectors, I had a bad one. That fixed all of my problems, if you do a search you should be able to find the thread. Good luck.
1993 37,xxx miles
Splines Lubed
Turn Signals Relocated
Hard Saddlebags
Acct Springs Replaced
KAT is offline
post #6 of 6 (permalink) Old 03-18-2015, 11:48 PM
Chasin' the blacktop
Spencer1's Avatar
I'm thinking ignition switch or a petcock that is barely opening.
North Georgia
Spencer1 is offline
